Would these kit be acceptable?
Old Sep 18, 2010 | 11:31 AM
MJZak's Avatar
MJZak
Default Would these kit be acceptable?
Would these kits be acceptable for use in a car that will be used to tool around town and back and forth to work?Including the 1" lowering 620 springs and kyb shocks it would still keep me around the $600 dollar mark.I will also be doing the Shelby drop.
http://www.cal-mustang.com/DELUXE-FR...-KIT-C882.aspx
I was also thinking about this kit for the steering.
http://www.cal-mustang.com/STEERING-KITS-C1869.aspx
Im not building a hot rod just a good solid daily driver for my son.As it sits now the suspension is COMPLETELY shot.All the bushing are cracked and pancaked as well as some metal to metal at the tie rod ends.Not safe at all!
As a disclaimer this is my first time doing the suspension in any car.
What do you guys think?
Old Sep 18, 2010 | 12:24 PM
67t5ponycoupe's Avatar
67t5ponycoupe
I put 620 coils on the front of my 67 and don't like them. The car rides like a buckboard. I would avise you to go with a softer spring. The kit your linked looked like it would do the job.
Old Sep 18, 2010 | 01:52 PM
67mustang302's Avatar
67mustang302
I don't find my 620's all that stiff really. Some of it is personal preference, but a lot depends on what you want the car to do. 620 is generally considered the limit for a small block car used on the street though. If it's just for a driver and handling isn't a major concern, then a 620 will probably be too stiff for you.
Old Sep 18, 2010 | 05:27 PM
MJZak's Avatar
MJZak
Thanks for the heads up on the 620 springs guys...comfort is what im looking for.
Does anybody else have any opinions on the two kits i listed before i hit the purchase button?If its junk id like to know before hand.Because honestly i have no idea one way or the other.
Old Sep 18, 2010 | 06:48 PM
67t5ponycoupe
Both kits look like they will work well for you. If you are going with KYB's I would recommend the GR2's for street driving. The gas adjusts are a bit too stiff and the GR2's are much cheaper.
Old Sep 19, 2010 | 01:04 AM
andrewmp6's Avatar
andrewmp6
I would read this first before buying anything http://home.bresnan.net/~dazed/suspension101
jwog666
Dec 27, 2021 08:09 PM
baddog671
Jul 26, 2016 01:20 PM
flash_xx
Oct 16, 2015 07:23 AM
Drastang
Sep 30, 2015 03:48 AM
