Replacing Lower Cowl Panel
Old Sep 21, 2010 | 08:28 AM
unit91's Avatar
unit91
Question Replacing Lower Cowl Panel
I want to replace the lower cowl panel in my 68. Other than the panel itself, what other parts would I need and what steps need to be followed to remove and install? I have the original fresh air vent assembly. Also, I noticed there are repair panels for these cowls. Is that something that has to be welded on after the bad part is cut out? Can't see repairing it - looks like an entire cowl panel would be better and easier to do. The only bad place in mine is where the fresh air vent was located.
Old Sep 21, 2010 | 08:33 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
you gotta pull the glass and all the vent stuff attached to the cowl panel...its a lot of drilling spot welds to remove the upper panel the lower will need to be cut out and the new stuff welded in some people use panel bonding adhesive for the install but its all up to you
Old Sep 21, 2010 | 11:37 AM
2+2GT's Avatar
2+2GT
Here's a look at the cowl:
Mustang Cowl Repair
Old Sep 21, 2010 | 11:09 PM
hightower2011's Avatar
hightower2011
Mustang Cowl Repair
Dear 2+2GT,
You are the librarian of infinite mustang knowledge.
Your wisdom runs far and wide in the depths of mustang-ness.
You are seemingly unrivaled in your mastery of anything and everything MUSTANG.
Basically, you're awesome.
Many thanks,
hightower
Old Sep 22, 2010 | 07:47 AM
2+2GT's Avatar
2+2GT
I shall now blush.
Old Sep 22, 2010 | 08:27 AM
andrewmp6's Avatar
andrewmp6
2+2gt is like me see's something useful i might need later and saves the link.
Old Sep 23, 2010 | 09:00 AM
unit91's Avatar
unit91
Good info........thanks!
Old Sep 24, 2010 | 05:09 PM
Bitter's Avatar
Bitter
If it's just the left side, you can get away with a partial panel. But after drilling all those spotwelds, I'd suggest a full panel with a good dose of paint.
2007CalSpec
Dec 13, 2020 11:42 AM
5.0muscle
Jan 11, 2016 01:17 PM
PullTab
Oct 30, 2015 08:46 AM
copestang
Oct 11, 2015 07:17 AM
StalkerGT
Sep 25, 2015 02:41 PM
