strut rod removal
Old Oct 4, 2010 | 07:33 PM
corzy's Avatar
corzy
Default strut rod removal
Hey guys, just wondering if theres a secret to getting the big bastard nuts off the strut rods on the front end, other than i guess heat which will obviously ruin the bushings, (and a 1 1/8 deep socket, i only have shallow ones )
Pretty sure its called a strut rod, its the one that goes from the lower control arm to the angled frame thats attached to the rad support.
thanks
Nick
Old Oct 4, 2010 | 07:44 PM
Starfury's Avatar
Starfury
Spray liberally with PB Blaster or another good penetrating lube (WD 40 is not a penetrating lube). And a deep socket
Old Oct 4, 2010 | 08:15 PM
corzy's Avatar
corzy
ya ok, ill try again...running out of pen oil on this car already hahaha
Old Oct 5, 2010 | 05:35 AM
gjz30075's Avatar
gjz30075
Jack the car up high enough to use a long breaker bar. Use plenty of PB Blaster. Don't expect to totally remove the nut while the car is jacked up because the rod is under great tension at this point, unless the lca is also jacked up to level it out.
Old Oct 7, 2010 | 08:18 PM
SLuckel's Avatar
SLuckel
I completely stripped my '68 coupe for restoration and I used a ton of penetrant oil. On the strut rods, I used a little heat and penetrant oil but left the strut rod attached to the lower control arm and alternated between an impact air gun and a substantial breaker bar. After patience I broke both sides loose. Good luck.
Old Oct 7, 2010 | 09:15 PM
Bitter's Avatar
Bitter
I had to use a Sawsall and replaced them with adjustables.
Old Oct 8, 2010 | 06:00 PM
corzy's Avatar
corzy
well 1 night soaking in Pen oil, then another 2 drenchings later, deep sockets and a 2 foot breaker bar, voila!!! came apart no problem....i am a believer!
thanks guys
jwog666
Dec 27, 2021 08:09 PM
baddog671
Jul 26, 2016 01:20 PM
Dathan
Oct 5, 2015 05:52 AM
jrrhd73must
Oct 2, 2015 09:17 PM
UrS4
Sep 30, 2015 10:13 AM
