flexplate
Old Oct 7, 2010 | 05:28 PM
skycranemech's Avatar
skycranemech
Default flexplate
Ok purchased a rebuilt 302 motor to install into my 1965 mustang, the old 302 was pretty wore out. I do not know what year engine forgot to look at stamping. question is going to by a new 157 tooth flex plate which I am assuming is going to have a weight on it, If this is a externally balanced engine, How or where do you position the placement of the flexplate in relations to the crackshaft? What are your opnions on harmonic balancers? Rebuilders say this is a heavy crank 302, good bad, indifferent? Thanks Bob
Old Oct 7, 2010 | 05:55 PM
2+2GT's Avatar
2+2GT
It's impossible to mount a Ford flexplate or flywheel wrong, the bolt holes will only line up one way. As long as you have the correct balance for the new engine, i.e, did you get a late model 5.0 or the earlier 302, you'll need the 28 oz type for the 302, and 50 oz for the 5.0. You really need to know what you bought.
Old Oct 7, 2010 | 06:35 PM
skycranemech
I should of wrote the numbers all down before I toof off for work these couple weeks. I didn't remember any alignment pin, so I was hoping the flexplate had a hole or something offset a bit. Funny I can tear apart an reassemble a helicopter but car parts combinations scare me.. Thanks
Old Oct 7, 2010 | 07:03 PM
Gun Jam's Avatar
Gun Jam
So i gotta ask
This isnt you is it??
http://www.youtube.com/watch?v=kQCC_n_5bR4
Old Oct 7, 2010 | 08:43 PM
2+2GT's Avatar
2+2GT
Yeah, but the main rotor head is symmetrical, the six bolts on the flywheel are not.
Old Oct 8, 2010 | 08:32 PM
skycranemech
worked on those for 12 years , not with heavy lift though.
injected331stroker
Jul 15, 2006 08:45 PM
injected331stroker
Jul 10, 2006 10:23 PM
sniper626
Apr 12, 2006 03:45 PM
bdwjdw
Feb 24, 2006 07:53 PM
rpm4lalo
Dec 12, 2004 12:35 PM
