64.5 260 problem
Old Oct 8, 2010 | 10:21 AM
dpellicone's Avatar
dpellicone
Default 64.5 260 problem
Guys and Gals, looking for some input on a issue with my 260. The car will start but when it is put in gear it run but will not accelerate. It has a rebuilt carb, new plugs, wire etc. The heads have been off and totally rebuilt valves replaced etc. New fuel tank, fuel filter.
Any thoughts?
Thanks
Old Oct 8, 2010 | 12:34 PM
2+2GT's Avatar
2+2GT
Accelerate as in it starts to misfire like crazy?
Old Oct 8, 2010 | 12:55 PM
dpellicone's Avatar
dpellicone
Yes Sir! Starts to accelerate then just cuts off.
Old Oct 8, 2010 | 01:56 PM
2+2GT's Avatar
2+2GT
Well, most likely it's an ignition problem. Even if the accelerator pump in the carb was inoperative, you could accelerate, just not real hard. Check dwell, condenser, and coil.
Old Oct 8, 2010 | 06:49 PM
67t5ponycoupe's Avatar
67t5ponycoupe
Also check the diaphram on the vacuum advance. If the diphram is ruptured it will cause that problem.
Old May 28, 2017 | 10:37 PM
sremle's Avatar
sremle
I had a condenser act like that on a SOB (Some Other Brand) car back in the 70's. Did you ever figure it out, since this was over ten years ago?
Old May 29, 2017 | 09:39 PM
Gun Jam's Avatar
Gun Jam
Dude I know 6 post are rookie numbers but there are better ways to pump them up.
Old May 30, 2017 | 07:09 AM
sremle's Avatar
sremle
Some guidance here would be better than threats.
Old May 30, 2017 | 07:12 AM
sremle's Avatar
sremle
There never was an answer here to the problem. Means it never god fixt?
Old May 30, 2017 | 10:34 AM
Gun Jam's Avatar
Gun Jam
Read the Private message I sent you
Cheers
-Gun
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
