Headlight problem, no low beam anymore
Old Oct 21, 2010 | 06:17 PM
blazerdup's Avatar
blazerdup
Question Headlight problem, no low beam anymore
SO here's the scoop. I was driving home from work in a huge down pour. I had my headlights on and everything was working fine. I of course couldn't avoid running through some large puddles and standing water. By the time I made it home my low beams had quit working. The parking lights come on, high beams work, and all interior lights still work.
No low beam lights now. What gives? I am stumped. Is it possible the headlight switch crapped out?
Old Oct 21, 2010 | 06:18 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
probably a bad dimmer switch....
Old Oct 21, 2010 | 08:56 PM
JMD's Avatar
JMD
+1,,,,,,,
Old Oct 21, 2010 | 09:18 PM
nba1341's Avatar
nba1341
Make sure the dimmer switch didn't melt or anything. Could try cleaning the connector first and see if that fixes it otherwise just get a 6 dollar dimmer switch
Old Oct 23, 2010 | 08:35 AM
blazerdup's Avatar
blazerdup
I will give that a shot. Thanks.
Old Oct 24, 2010 | 11:40 AM
Oxnard Montalvo's Avatar
Oxnard Montalvo
As mentioned the dimmer is likely bad. Do a resistance check on the dimmer with a multimeter to check it's two position operation, and take a good look at the wiring connector. If you don't have a multimeter you could jumper the connector with a paper clip to eliminate the wiring.
musnicki
Sep 23, 2015 07:11 AM
Mustangmalo
Sep 6, 2015 05:22 PM
zanemoseley
Sep 6, 2015 12:58 PM
