66' wont run
Old Oct 31, 2010 | 05:00 PM
kevinhecky's Avatar
kevinhecky
Default 66' wont run
hey, im new to these forums.. but here goes.
i have a 1966 convertible with a 200ci inline 6
it sits in my garage and comes out every weekend, except this one.
the battery was initially dead, so i charged it. when i turn the key the motor cranks but wont start.
things ive checked:
carb: cleaned and inspected. looks good.
spark plugs: replaced.
distributer: tested, good.
compression: good.
im running out of ideas.. any thoughts and input would be greatly appreciated.
Old Oct 31, 2010 | 06:06 PM
MustangFTW
Guest
Posts: n/a
same problem here battery was dead while it was charging (other car running and still connected by jumper cables) i tried starting it, it would crank but was REALLY hard to start but once it started it started fine since.
Old Oct 31, 2010 | 08:58 PM
5'Oclocksomewhere's Avatar
5'Oclocksomewhere
Check all your fuses, sounds like a fuse problem.
Old Oct 31, 2010 | 09:00 PM
mr_velocity's Avatar
mr_velocity
Fuel and spark. You say you tested the distributer does that mean you have spark? You cleaned the carb, is it getting fuel?
Old Nov 1, 2010 | 05:15 AM
kalli's Avatar
kalli
+1. check if you are getting spark. if you do then you're probably not getting fuel.
check quickly with aircleaner off and choke butterfly open (hold open):
- accellerate once fully (you can use the throttle linkage at carb). you should see fuel squirting into the carb when you do that
Old Nov 1, 2010 | 11:57 AM
kevinhecky's Avatar
kevinhecky
i have fuel and spark. still cranks but wont run.
Old Nov 1, 2010 | 12:08 PM
mr_velocity
plugs getting wet?
Old Nov 1, 2010 | 05:37 PM
001mustang's Avatar
001mustang
If you are sure you have fuel and spark; Position #1 at TDC and verify timing is close.
I would try a couple shots of starting fluid first; some people don't like starting fluid.
Oct 7, 2015 07:02 PM
heslekrants
Sep 23, 2015 04:02 PM
TorinoCobra070
SVT Forums
Sep 18, 2015 10:34 AM
MusicCity615
Sep 12, 2015 07:05 AM
uedlose
Sep 10, 2015 03:30 PM
