Differential rebuild
Old Nov 1, 2010 | 11:10 PM
racer_dave's Avatar
racer_dave
I use a thick, flat blade putty knife to separate the gaskets,housing,diff. Its not uncommon and even if you have to get in there with a flatblade screwdriver you won't hurt anything. I have to do this all the time on the race cars.
Make sure the jack is under it so it doesn't pop out, fall and smash your hand. Not that that ever happens :-)
Old Nov 23, 2010 | 12:12 AM
67 newb's Avatar
67 newb
Differential ready to go!
I got the 3rd member out with a little tapping of a screw driver all around. Then I had the axle housing on some milk crates and carefully flipped it upside down. The weight of the differential alone pulled the whole thing out.
Turns out my gears are 2.79, no trac loc (wcz-v1 on the tag). I got an overhaul kit which included all new bearings, crush sleaves and seals. Also got new axle bearings and seals. That total cost about 200 bucks, plus another 16 for shipping.
A guy in Gilroy rebuilt the differential and replaced the axle bearings for me. Cleaned the whole thing, painted, set the pinion, adjusted ring gears and bearings and set the backlash to .010". He replaced the axle bearings too. That was about 300 bucks.
So total is about $500 if your parts are decent and you're not looking to upgrade.
Does anyone know how many lbs to torque the 3rd member to the axle housing?
Old Nov 23, 2010 | 08:15 AM
001mustang's Avatar
001mustang
25 to 40 lb-ft.
Don't forget to seal mating surface w/ silicone and copper washers under nuts.
mtgldr
Feb 3, 2024 09:00 PM
Dathan
Oct 5, 2015 05:52 AM
UrS4
Oct 3, 2015 06:23 AM
KingRando
Oct 2, 2015 08:06 AM
Drastang
Sep 30, 2015 03:48 AM
