Bondo not drying...
Old Nov 7, 2010 | 09:19 PM
001mustang's Avatar
001mustang
You may not be able to get pin holes in rage evercoat but I sure can.
I've had less pin hole issues w/ bondo.
Bondo will last well over a decade.
The old one stage puttys will shrink and I wouldn't use them.
Bondo is harder to sand than rage evercoat but may be more durable; time will tell.
I think bondo got a bad rap because yahoos used to pile it on 1" thick over rusty panels.
Old Nov 7, 2010 | 10:11 PM
001mustang's Avatar
001mustang
Default Few bondo data points
I got curious about comments saying bondo holds water like a sponge....swelling...shrinking.
Bondo specifications according to 3M:
% water absorption < 0.3%
% shrinkage < 0.5%
http://multimedia.3m.com/mws/mediawe...SevTSeSSSSSS--
Old Nov 8, 2010 | 01:19 AM
chris66dad's Avatar
chris66dad
% shrinkage < 0.5%
I based the statement on what I read on hotrodders paint forum. It was stated to never wet sand over bondo because it will absorb the water.
Based on those numbers it does not appear to be a problem.
But then again I have always been told to never let a bondo repair sit in in weather with out a topcoat on it
Old Nov 8, 2010 | 07:22 AM
mr_velocity's Avatar
mr_velocity
Both Bondo and Rage Gold are polyester resin based products, both will absorb a slight amount of water so I wound't leave either wet.
In this day and age I'm surprised that manufactures, on the automotive side of things, haven't moved to vinylester or epoxy based fillers. Both are completely waterproof and provide much better adhesion. In the marine industry both are common.
Old Nov 8, 2010 | 07:44 AM
JMD's Avatar
JMD
Originally Posted by MustangFTW
i went and checked out the Rage stuff... is it really worth the price? 4 times more then bondo for the same amount. anyway i got it fixed right. hopefully ill be painting sometime this week. any comments on paint setup? im decideing between the original ivy gold that matches the interior, black, or possibly red. im probably gonna use my dads 4 car garage to paint it has a ceiling window so ill take it out and stick a fan for ventilation, going to make kind of a cube of plastic so i dont have to heat the whole garage (going to be anywhere from 50-60F) would i need a primer if no metal is exposed? any suggs on the brand/type of paint?
There is other lightweight stuff that is way "good enough", I use a brand called Z-Grip, IMO it is almost as good as the Rage products for about $15.00 a gallon.
Whatever you do for a booth, watch out for extreme vapor build up.
Old Nov 8, 2010 | 08:06 AM
MustangFTW
Guest
Posts: n/a
so do i need primer even though there no bare metal?
Old Nov 8, 2010 | 08:52 AM
001mustang's Avatar
001mustang
I wouldn't expose bondo to excessive UV rays.
When any filler is used over bare metal I get concerned when metal starts to flash rust near feather edge.
I have washed bondo over bare metal w/ water based cleaners many times.
Many body shops love other fillers because they can sand them faster; but bondo does not take that much longer to sand.
I just checked a metal patch bondo paint repair I made in the 90's; repair is still straight as an arrow. Hope my evercoat rage repairs last that long.
Clu7ch
Jun 6, 2006 02:08 AM
Littlepepe27
Mar 23, 2006 06:21 PM
Littlepepe27
Mar 23, 2006 02:55 AM
mustang_montana
Aug 21, 2005 03:13 AM
tron
May 12, 2005 02:53 PM
