Speedo Gear
Old Nov 6, 2010 | 04:48 PM
tx65stang's Avatar
tx65stang
Default Speedo Gear
I've somehow managed to lose my speedo gear. I've pulled the tail shaft from the tranny housing and counted 9 teeth. According to the data plate, my axle ratio is 2.8:1. Rear tire height appears to be 24.25" (215/60r15). I've checked a calculator online and came up with 15. I assume this means I need a 16 tooth type 3 (C4). But I don't know what the color references are. Is this for the tooth angle? How would I need to determine the correct color?
Here is a shot of the driven gear.
http://s963.photobucket.com/albums/a...65stang/Share/
Old Nov 6, 2010 | 08:43 PM
2+2GT's Avatar
2+2GT
You did way too much work. In future, pull the cable, put a dab of white grease on the gear, and turn the driveshaft, counting the teeth until you get back to the dab.
You photo shows the drive gear.
I keep coming up with - you need a 21T gear.
http://home.mchsi.com/~jroal/drive.htm
Old Nov 6, 2010 | 11:36 PM
JMD's Avatar
JMD
I hate the speedo gear crap,...................
Thunderball
15
Nov 22, 2015 11:49 PM
Bokeo
Oct 10, 2015 08:28 PM
KingRando
Oct 2, 2015 08:06 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
