Winter storge options
Old Nov 7, 2010 | 02:44 PM
tcrote5516's Avatar
tcrote5516
Default Winter storge options
So I put my car away at the end of October for the winter. I'm on the MA seacoast and it seems the salt air is already chewing up my hard work. Aluminum is corroding and some on the non stainless hardware is starting to rust.
Its in a 2 bay garage with my other restored pickup that is seeing the same damage. Well I cannot let this happen. I started searching the web and came across this : http://www.carbag.com/
I just ordered one, but was wondering if any of you have had experiance with these car bag's/jackets. Seems like a perfect solution. I have 2 chemicals, 1will dry out the air and the other will remove most of the oxygen...should just about freeze time in terms of preserving the car for the next 5 months.
Old Nov 8, 2010 | 04:19 AM
NoReins's Avatar
NoReins
I have not had any experience with these storage systems but I have heard of these...
http://www.carcapsule.com/
or this
http://www.theultimatefinish.co.uk/a...amber-car.aspx
Here is a link that discusses some of the issues with these types of covers:
http://www.gt40s.com/forum/all-gt40/...e-cocoons.html
I'd also recommend a dehumidifier, especially for your climate out on the east coast. Hope this helps.
Old Nov 8, 2010 | 08:20 PM
001mustang's Avatar
001mustang
Aside from the obvious battery removal and carb fuel removal would you consider buying two shinny steel washers? Put one in the bag and the other in the garage bay. Compare in the spring to gauge bags effectiveness.
Old Nov 9, 2010 | 06:28 AM
67 evil eleanor's Avatar
67 evil eleanor
Here's somthing I wrote up a couple of years ago. It would be nice to have a desiccate dehumidifer in the garage as these are not sensitive to freezing. I have never found one in the US that would be suitable for a small garage that is less than $500.
Well its that time again. Time to put our Steed in the barn for good Winters rest. It seems as Winter approaches a lot of storage questions arise. So, this is my attempt to share some storage tips that have worked for me.
#1 Environment. As you know its better to keep your car stored inside and out of the elements. A good clean garage is a great place to bed down your Horse for the winter. The ideal environment would be one that is climate controlled with both heat and humidity. But for most of us this is out of reach. The ideal humidity level would be between 40 and 60% where as corrosion all but stops (think of a Arizona car) and a constant tempature. Less than 40% promotes dryrot with the vinal and rubber. Another issue is a concrete floor. Concrete floors are great but can allow mosture to collect in the form of condensation. This will form on the bottom of your car and setup ideal conditions for rust on the unibody and reek havoc the exhaust system. A simple layer of polyethylene plastic will help keep the mosture trapped and not allow it to move up.
#2 Tempature. For those of us living in freezing areas this is an issue. The antifreeze needs to be checked with a Hydrometer or Refractometer. The Hydrometer works only on Ethylene Glycol based coolants/antifreeze and not on Proplyene Glycol based solutions. The Refractometer can be used with either and is the one I perfer. For you race car guys that are running straight water and maybe a cooling enhancer (Redline water wetter), you need to add or change over to a 50/50 solution of antifreeze. Also remember that antifreeze wears out. Over time the corrosion protection additives will weaken and the coolant may become acidic. It seems that most manufactures recommend every 30,000 miles or three years. There is a lot of room for discussion on the types of coolants (IAT, OAT, and HOAT) and their intended use. You will need to do some research on which is best for your engine build and cooling system and make your own determination. "Electrolysis" is a good indicator that the coolant is too acidic. You can check this with a volt meter and the engine running with the electrical system under full load (make sure the radiator is not pressurized). Stick one probe on the negative post of the battery and the other in the coolant. Anything over 400 millivolts means the coolant is shot and is in need of replacment. Also check the windshield washer fluid as some are not freeze proof and these will need to be drained or changed to a winter washer fluid.
#3 Fuel. This is one that is a very fix but often overlooked untill Spring when you turn the key only to be disappointed. Todays "pump gas" will start to break down in a matter of weeks. This will leade to the formation of a varnish like substance and clog your fuel system. The simple solution is the addition of a fuel stabilizer. Its only a few bucks and can save you hundreds in the Spring. Be sure to top off the tank once the stabilizer is added.
#4 Battery. This can be removed or left in. If you plan to leave it in the car, then you need to use a trickle charger to keep it healthy. Make sure to disconnect both cables from the car before connecting the charger to the battery. If you leave the cables hooked up, then you have the potiential for a source of ignition if something in the electrical system fails or is damaged by a rodent. If removed, it needs to be placed on a wood board or rubber backed carpet and not on the bare floor. Storing it in a warm location and charging it once a month will keep it healthy.
#5 Tires. For the long sleep you need to inflate the tires to the maxium listed pressure if you don't plan to use jackstands. Just don't forget to adjust them in the Spring or when you take it out of storage. It seems that most modern radial tires are not prone to flat spotting due to winter storage. If you have the old vintage or original (haha) type, then jackstands are a must.
#6 Protecting the finish. Before you put your baby away give it a good cleaning and wax job. Vacuum the inside and use some protectant on the vinal and rubber. I use WD40 on all the chrome both on the inside and outside. It will leave a film that will protect the chrome from corrosion and usually last untill spring. A car cover is a good idea also. I perfer a 100% cotton cover if stored inside a garage. If under a carport or outside, you may want to make sure the cover is secure. The wind can cause it to rub the paint off if left loose. Remember that when buying a cover, "water resistant" is not "waterproof". I see a lot of people using a water resistant cover then placing a waterproof tarp on that and using about 50 bungee's to tie it all down. This seems to work well if no indoor garage is available. The last thing is mold. I leave the windows cracked about 2 inches when in storage. This will allow some air flow and reduce the chance of mold. Nothing like uncovering in the spring and finding out the interior has changed colors.
#7 Mechanical. Cars like to be run. When we don't, they get mad and cause us trouble. Check and fill all the fluids before, during, and after the storage period. Also grease the suspension and don't forget the U-joints. When greasing the front suspension, its a good idea to have the car on jack stands. Once done, move the steering wheel back and forth to distribute the grease. With the weight off, the grease will move more freely. While the front wheels are off the ground, its a good time to look at the wheel bearings. Wheel bearing grease can dry out and cause bearing failure. While the wheels are off, take a look at the brake pads or shoes. Its a good time to change them if they are worn. Don't forget about the rear. When checking the rear brakes, look to see if theres any leakage of oil from the axle seals. Sometimes this goes unnoticed untill a problem arises. When in storage try to start your car at least once if not twice a month. When you do, bring it up to operating tempature. If only started for a few minutes and not allowed to heat up, condsation will quickly form and may cause internal injury to the engine and drivetrain. Also its a great time to engauge the A/C and work all the electrical devices. If possiable put it in gear and move it back in forth. This will help keep things lubricated.
#8 Rodents. No, not your cousin Vennie or uncle Bob, but those little furry creatures with long tails and sharp teeth. For me, I do a three step protection. It starts outsied the garage with poison bait blocks. Hopefully I can get them on the outside before they move in and cause damage. You have to be careful around other pets and children and follow the warning labels, but it has been very effective for me. The second is mouse traps. I always keep several traps baited and set. This lets me know if any of the little creatures have made it in. Also I have poison blocks in hidden locations where I think they may want to hide. The last is soap. I keep a couple of bars of "Irish Spring" in each car. I open the box and sit it in the floors. So far it seems that it works. If it don't, at least the car will smell springtime fresh when it comes out of storage.
This is what I do and there may be a better way, but so far this has worked for me.
Old Nov 9, 2010 | 10:27 AM
jspagna1's Avatar
jspagna1
I live in CT as well and boy those Winters are looong!
I've had my car for 14 years and it still looks pretty good if I say so myself.
I store my car in a garage. What I ussually do is the following:
1.Top off the tank and add a fuel stabalizer.
2.I put bars of Irish Spring soap in the interior to keep out the rodents and it smells better than moth *****. Also put down the sun visors as well.
3.Wash & wax car and use a good breathable car cover-not a cheap one.
4.I just disconnect the battery, but leave it in the car.
5.I also have found that covering the motor with large bath towels keeps that condesation from building up and staining the chrome and aluminum parts.
6.Also if the car is stored in a garage with a concrete floor like mine is,you want to get a large plastic sheet and lay it on the floor and this protect the condensation that rises from concrete floors and prevents corrosion on the car as well.
So read all these suggestions that people have made and see which ones work for you.
http://www.cardomain.com/ride/257631...ang-conn-ct-us
Old Nov 9, 2010 | 05:46 PM
tcrote5516's Avatar
tcrote5516
Some great tips here guys, thanks!
I like the idea about covering the block with bath towels...makes alot of sense and I never thought of that simple fix.
I'll post my experiance with this "mustang sleeping bag" and will do the washer test so everyone can see the results.
Thanks for the input!
jwog666
Dec 27, 2021 08:09 PM
01GTon18s
Oct 13, 2015 04:44 PM
ChampInSD
Oct 2, 2015 04:55 AM
GTJIM
Sep 23, 2015 09:59 AM
Art161
Sep 9, 2015 10:33 AM
