t5 swap??????
Old Nov 9, 2010 | 03:39 PM
CyprusMustang's Avatar
CyprusMustang
Default t5 swap??????
anyone know what i would need to swap my c4 for a t5? i got a 302 engine.
Old Nov 9, 2010 | 06:27 PM
2+2GT's Avatar
2+2GT
Lots of places can provide this. Glazier/Nolan has done many of these, and they are quite good at export.
Old Nov 9, 2010 | 06:56 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
you will need a pedal assembly, a flywheel, clutch shortened driveshaft new crossmember thats most of it
Old Nov 9, 2010 | 11:35 PM
TexasAxMan's Avatar
TexasAxMan
You don't necessarily need a shortened driveshaft, every car is different. I had a 6 cly coupe with auto, found a set of pedals, traded my rebuilt C4 for a T5, bought a flywheel and clutch, a new crossmember and installed it. Everything worked out fine, I have about an inch of travel in the slip yoke.
I rebuilt mine, and it's pretty easy. Let me know if you need my sources. You should really put a steel front bearing support on a T5, I had to as the original was chewed up a bit, originals are aluminum.
PM me if you need any further information. I was terrified to try it but it all went pretty well for me. I'm using the z-bar (no cables for me) and tri-y headers and all is well.
Oh, and rmodel65, your sig quote is offensive to anyone that has any sense, please consider changing it.....
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Bokeo
Oct 10, 2015 08:28 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
guitarman376
Sep 30, 2015 05:54 PM
UrS4
Sep 30, 2015 10:13 AM
