Bent and grinding pushrods
You got it. ordered some real nice roller rockers ( http://home.earthlink.net/~kaneofthe...mics/id19.html )
Will get proper pushrod length using the check I have once my pushrods are in. Additionally, I've upgraded studs to 7/16 (rockers are 7/16 as well) and guide plates for the 7/16ths. It looks like there's good room to accomodate this in the pushrod holes, so why not go even stronger!
What kind of Redline are you using... is it the type that has the ZDDP? What thickness should I get?
I can't recommend a weight for your motor.
I'm gonna pull the intake, install new hardened pushrods and new roller rockers as suggested using the correct EOIC method.
As for the heads I'm reluctant to take them off (never done it before) - how difficult is it, do I have to replace gaskets in that case? And how do I check the valves for wear?
Yes, head gaskets cannot be reused. The Factory Service Manual has detailed guides.
Noone can recommend a good oil? Living in Arkansas atm: averages around 20-50 degrees in the winter - 90+ in the summer.
KingRando
Oct 2, 2015 08:06 AM
JDWalton
Sep 24, 2015 08:47 PM
