Shortening steering column
Old Apr 27, 2012 | 07:40 AM
mainiac1's Avatar
mainiac1
Default swapping to 68 column
Thanks for the info. I think I can use the tube as is and put the original firewall clamps on the drivers side of the firewall, then cut the orig 66 shaft and mate the 68 slightly shortened shaft to it via a ragjoint or universal.
Did you find anyone that sells the replacement plastic sleeves that go inside the tube at the lower end?
Thanks, Jamie
Old Apr 28, 2012 | 01:39 PM
mr_velocity's Avatar
mr_velocity
Thanks, Jamie
At the lower end I welded in a bearing since this is being use with a Rod&Custom front end.
lincolnshibuya
Dec 8, 2020 01:49 PM
CS2007
Jun 25, 2019 09:45 PM
ChampInSD
Oct 2, 2015 04:55 AM
allenmaty
Sep 24, 2015 09:17 AM
stark777
Sep 21, 2015 12:46 PM
