chassis support? suspension?
Old Dec 11, 2010 | 07:31 PM
J-1969's Avatar
J-1969
Default chassis support? suspension?
1969 mustang 302. any one have any suggestions for sub-frame connectors and roll cages. and good sway bar or suspension kits that has the best bang for the buck. i have a lot of play in my steering. it handles very sloppy. any info will be greatly appreciated.
Old Dec 11, 2010 | 09:07 PM
mr_velocity's Avatar
mr_velocity
Best bang for the buck? All relative. Here is what I'm doing https://mustangforums.com/forum/clas...edstang-9.html To me, this is the best bang for the buck. How much you want to spend?
Old Dec 12, 2010 | 02:25 AM
eZ's Avatar
eZ
what kind of budget? The play in your steering is a diff subject than suspension. Lots of diff options give us an idea of budget first. For subframe connecters there are many options I made my own version of tinman fabrications.
Old Dec 12, 2010 | 04:41 PM
2+2GT's Avatar
2+2GT
First off, the steering was tight when new. Likely it just needs proper adjusting, as per the Ford Service Manual. Don't just start tightening things, that can easily destroy the gearbox.
Second, for better handling at little cost, do this:
Arning/Shelby Suspension Drop
Old Dec 12, 2010 | 06:26 PM
J-1969's Avatar
J-1969
whatever is reasonable really. ill pay what is needed to get what i need but i wont pay twice as much for one thing as another just for a name or anything like that.
Old Dec 12, 2010 | 06:29 PM
zmetalmilitia's Avatar
zmetalmilitia
There are many direct bolt in upgrades you can do to complete suspension overhaul which require a complete tear down of the front end. That all depends on what you want. A 1"" sway bar is a quick and easy upgrade and, as 2+2GT mentioned, the shelby drop. There are subframe connectors you can install which bolt in or weld in if you can. There are bolt in rack and pinion setups that can improve steering. Just research what you want and then decide how much you want to spend. Shocks, coil overs, roller perches, springs, tubular arms, disc brakes, etc. the list can go on and on.
Old Dec 12, 2010 | 06:39 PM
mr_velocity
You really need to throw out a budget number. What is reasonable to one is very costly to another.
To get what you need, again very relative. For a daily driver I'm replacing the suspension with coil overs. Some say it's not needed, I say it is.
Old Dec 12, 2010 | 06:53 PM
J-1969's Avatar
J-1969
like i said i will pay what i have to pay but if you really need a # i aint looking to pay more than five or six hundred for one upgrade. im not looking to rebuild, just some upgrades from what is already on it.
Old Dec 12, 2010 | 07:01 PM
2+2GT's Avatar
2+2GT
OK, rack and pinion is out.
Old Dec 12, 2010 | 07:13 PM
J-1969's Avatar
J-1969
i really just want to get rid of the sensitivity in the steering. thats my main concern for now. i have new gas shocks in the front and the guy i got the car from put air shocks in the rear. it rides good. the annoying thing is i can move the wheel just a little and the car shoots off to whatever side i turn the wheel. ive been told its my suspension thats causing that.
