primer
Old Dec 14, 2010 | 07:38 PM
  #21
NoReins's Avatar
NoReins
70 is optimal. 60 degree metal temp is acceptable, but not a degree colder. The primer will NOT cure and you will have problems. I would read the expoxy tech sheet also: http://www.southernpolyurethanes.com...oxy_primer.pdf
Old Dec 14, 2010 | 07:59 PM
  #22
Trigg's Avatar
Trigg
Thats a bummer I hope my two little space heaters will can hold up.
Old Dec 14, 2010 | 09:26 PM
  #23
hightower2011's Avatar
hightower2011
Damn, that sucks for me too. I'm going to have to break out the propane heaters in the barn to spray this winter.
Old Dec 14, 2010 | 09:36 PM
  #24
mr_velocity's Avatar
mr_velocity
We heat our house mostly with a wood burning stove, I don't want to see the gas bill from my 100,000 btu heater that has been running in the garage. If I had thought about it earlier this year I would have put a small stove in the garage too. If I could figure out a vent system without needing to cut a hole in the roof I would pick one up quick on CL. We burn about 5 cords of wood a year, I split while my wife stacks it all.
My brother-in-law has a small stove that came out of a caboose on a train, man does that thing throw a lot of heat.
Oh, don't paint and use open flame heaters. I usually get the garage as hot as possible, shut them down and don't restart them again until I'm sure the fumes aren't going to make us go boom.
Old Dec 14, 2010 | 09:50 PM
  #25
hightower2011
Thanks for the final tip, haha. I'm probably going to prime in 4 or 5 big sections, so I'll do what you did and after I finish spraying a section, leave it 'till it dries. No need to go boom just trying to speed things up.
Old Dec 15, 2010 | 07:58 AM
  #26
KMatch's Avatar
KMatch
Check out their forums. There is a used-up-car-lot repair guy shooting in the teens! Now, 60 IS the absolute minimum for US as it's packaged, but Barry has some tricks and additives for those not living in the south. Anyone not able to work in warm weather needs to contact SPI.
Old Dec 15, 2010 | 08:39 AM
  #27
NoReins's Avatar
NoReins
KMatch, could you share a link with us?
Old Dec 15, 2010 | 09:56 AM
  #28
KMatch's Avatar
KMatch
Whoops! It was clear and not primer. It's worth a look, still. Barry has a chemical major so he may have something up his sleeve for his other products.
http://www.spiuserforum.com/showthre...hlight=degrees
Old Dec 15, 2010 | 06:43 PM
  #29
Trigg's Avatar
Trigg
hmm, Chemical Major. Got to love smart peoples.
Old Dec 17, 2010 | 05:18 PM
  #30
BuckeyeDemon's Avatar
BuckeyeDemon
Congrats! I think you'll be pleased.
As far as the aircraft remover, that is what we're talking about but get the aerosol cans. Trust me, you don't wanna mess around with spreading that stuff and getting it on your skin. Plus the aerosol will stick to vertical surfaces a whole lot better.
i use the regular aircraft stripper. i had no problems spreading it even on vertical surfaces.
i believe you have equal opportunity of getting it on your skin during application as you do during the scraping process.
the aerosol sounds expensive.
