Spring rate
Old Dec 18, 2010 | 02:36 PM
eZ's Avatar
eZ
Default Spring rate
If Im running coil-overs both up front and rear what rate should I run. Does it how long the spring is make a diff.? Ive read up on it a bit and I know both front and rear need to work together. Anybody know what the front and rear of my car may weigh?
Old Dec 18, 2010 | 06:08 PM
67mustang302's Avatar
67mustang302
Depends on how you plan to drive it and the suspension configuration. Placement of spring mounts will alter how spring rates effect wheel rate.
Old Dec 19, 2010 | 01:59 AM
eZ's Avatar
eZ
I plan on driving it like I stole it. So where do we start? front coilover will attaxh to UCA and rear is a 4 link set up with springs set at about 30 degrees
Old Dec 19, 2010 | 04:06 AM
67mustang302
Drag racing, road racing etc. And is the front in stock mounting configuration? For the rear the manufacturer of the setup should have listed starting ranges for spring rates.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
CS2007
Jun 25, 2019 09:45 PM
PullTab
Oct 30, 2015 08:46 AM
mungodrums
Sep 28, 2015 10:54 PM
