which wire harness to get
However, since you are doing a restomod, you could just get an EZ wiring harness or a Ron Francis like I did. Do you plan on changing the gauges? I liked the ron francis. It came with pretty much everything that I needed and was only about $300 for the entire car. Plus when you order it you can just get what ever else you think you may need added to the kit. As long as you are pretty good with a soldering gun and some wire crimpers youll be good to go.
Next wiring job I do I will make my own though.
Only issue I have ever had with the R/F kits is the fuel gauge sender wire is routinely too short.
Talk to Midlife for some excellent refurbished ones at great prices.... http://www.midlife66.com/harnesses/welcome.html . I have used them and he does a great job and with a warranty.
I used the EZ wiring kit on a 1972 F100 and frankly for a Mustang I wouldn't recommend it. If you're building a street rod and running new routing of all wires then it's a good generic kit.
jwog666
Dec 27, 2021 08:09 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
breaking
Oct 2, 2015 01:27 PM
