Manual Gearbox
Old Jan 10, 2011 | 11:53 AM
coloradoblues's Avatar
coloradoblues
Default Manual Gearbox
Hi to you all .
A friend of mine got a 1969 mustang with a windsor engine and an automatic gearbox , now he looking to put up a manual gearbox , because here in Ireland the parts are a bit scarse to say the least , he's wondering if the European Sierra model gearbox can be suitable for the transplant or any other alternative .
Any detail that you need to know just ask .
Thank you for your help.
All the best .
Old Jan 10, 2011 | 12:03 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
you can use the late model 87-93 Mustang 5speed....
Old Jan 11, 2011 | 12:58 AM
andrewmp6's Avatar
andrewmp6
Your kinda stuck to a ford v8 rwd trans nothing else i know will fit with out a ton of work.
Old Jan 11, 2011 | 05:19 AM
coloradoblues
Thank you Andrew and Thank you Model , i much apprecciate your help .
Andrew i believe so myself , i just was asking around if someone had a way around it , but obviously not .
Infact i was telling him that the best thing to do, is to contact someone in the States and see if there possibility to purchase a Gearbox and be sent over , i do not know if is convenient for him but i think is the best solution , otherwise can keep the auto that after all works perfectly .
Talk to you later
Old Jan 11, 2011 | 07:18 AM
andrewmp6's Avatar
andrewmp6
Is there any rwd v8 fords over there that use a stick ?I believe http://www.moderndriveline.com/ can ship you everything you need but it won't be cheap.
Old Jan 11, 2011 | 08:15 AM
2+2GT's Avatar
2+2GT
You have mail.
Old Jan 12, 2011 | 05:08 AM
coloradoblues
Many thanks for your help so far.
I saw my friend yesterday and he and his mechanic are going ahead with their idea to try on the SierraConswort gearbox , they are stating that there is an AC cobra kit car sold with a chevy engine and the Gearbox mentioned above , therefore they are thinking that if it mount on a chevy engine this should well mount on a Ford ...
Does anyone have done such of a modification ??? or know about it ?
Ciao
Old Jan 12, 2011 | 05:28 AM
2+2GT's Avatar
2+2GT
Well sure, that's logical, any gearbox that mounts on a Land Rover should fit on a Jaguar, no problem. Are they serious?
Old Jan 12, 2011 | 09:39 AM
coloradoblues
Yes they are , my point is to pushing them to find a purpose make gearbox for that car , i don't even know if they 'd been able to find the gearbox in question , i doubt that and if easy to understand why , I mean about to find an used one , according to them if doesn't fit for sure there is a modification kit available .
I will pass over all the tips from here and they 'll decide .
Another think , i have been told that the car doens't do more than 10 miles per gallon !!!! in a normal use, i find it a bit heavy how many miles per gallon shoult it do ???
Many thanks
Old Jan 12, 2011 | 12:41 PM
2+2GT's Avatar
2+2GT
OK, all sarcasm aside, you will not be able to mount a Chevy transmission on a Ford engine without some major custom work. Any 86-92-ish Mustang 5.0 5-speed will install pretty easily, with a few adapters, and the stock clutch linkage for your year. IIRC, I sent you a link to get this done.
As for mileage, my 289 4V got 15-21, my 289HP 14-18, and my 200 got 18-25, all with stock manual transmissions. With a T5, you should easily get over 20 on the highway.
