1966 disc brakes
Old Jan 17, 2011 | 05:07 PM
bearsden's Avatar
bearsden
Thumbs up 1966 disc brakes
I put disc brakes on my 66 coupe. Need to know if brake light switch needs to be changed.
Old Jan 17, 2011 | 05:17 PM
2+2GT's Avatar
2+2GT
No.
Old Jan 17, 2011 | 10:54 PM
001mustang's Avatar
001mustang
Can't figure why you would think to change brake light switch? Not working?
Brake switch is located on pedal shaft (65-70), disc brakes don't affect it's operation so long as proper rod length maintained.
On 64 1/2, brake light switch is incorporated w/ master cylinder and would need to be delt w/ if OEM mc upgraded.
Old Jan 18, 2011 | 08:19 AM
2+2GT's Avatar
2+2GT
Reasonable question, 67-73 had a mix of different switches for manual, power drum, and power disc.
Old Jan 18, 2011 | 12:28 PM
001mustang's Avatar
001mustang
On 66 one brake light switch fits all. right?
Old Jan 18, 2011 | 12:52 PM
bearsden's Avatar
bearsden
When we switched over to disc brakes we also changed to a double mc. and power assist.
Old Jan 18, 2011 | 12:59 PM
Oxnard Montalvo's Avatar
Oxnard Montalvo
Smart move. The lousy emergency brake design coupled with the single bowl setup is an invitation for Mayhem.
http://www.youtube.com/watch?v=q9eqj7xRzk0
Old Jan 18, 2011 | 01:07 PM
001mustang's Avatar
001mustang
Did you keep original pedal support bracket and pedal which brake switch is mounted on?
Old Jan 18, 2011 | 02:49 PM
2+2GT's Avatar
2+2GT
On a 64-66, the same pedal and bracket were used power/non-power. This changed, 67-70 requires a special power pedal.
Old Jan 18, 2011 | 03:01 PM
001mustang's Avatar
001mustang
I was just curious if OEM 66 pedal assembly was changed for some reason; stranger things have happened.
If 66 has OEM pedal/support then standard 66 brake light switch should fit all 66 brakes.
I don't recall answer to why post started; problem w/ brake switch not working?
