64.5 260 distributor problem
Old Jan 30, 2011 | 06:25 PM
dpellicone's Avatar
dpellicone
Default 64.5 260 distributor problem
Folks, I am having an unusually hard time reinstalling my distributor. I cannot get it to seat all the way down. I have tried several different positions for the rotor. I feel i am at TDC and on #1 but it will not seat all the way flush. Know i am missing something easy!!!
Thanks
Old Jan 30, 2011 | 07:30 PM
001mustang's Avatar
001mustang
Need to be sure TDC after #1 cyl compression stroke.
Rotor needs to be positioned to fire #1 plug.
Need to verify oil pump drive shaft in position.
You've done the above I guess?
Did you install new O ring?
Did you install new dist gear?
Old Jan 30, 2011 | 09:09 PM
JMD's Avatar
JMD
What I always do is to get the distributor on the right tooth, and then roll the starter a little bit while gently pushing the distributor down.
The distributor gear and the oil pump shaft will usually match up within one turn of the engine and the distributor will drop the last 1/4".
Old Jan 30, 2011 | 10:01 PM
2+2GT's Avatar
2+2GT
This has worked many times for me.
Omgitsa88Stang
Oct 5, 2015 07:33 AM
StalkerGT
Sep 25, 2015 02:41 PM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
ccdguy
Sep 19, 2015 05:20 PM
jaiidutch
Sep 14, 2015 10:29 AM
