Crankshaft Bearings
Old Feb 8, 2011 | 10:35 PM
ColtonS3290's Avatar
ColtonS3290
Question Crankshaft Bearings
I have just started to mess with installing the crankshaft on my 1969 engine in a 1971 coupe, it has a 351w bored out .30 over, on the crank its .10 under on the journals and i do believe on the connecting rod journals as well. i was wondering if anyone knew the spacing for the main bearings for both the main journals and connecting rod journals?
Old Feb 8, 2011 | 10:46 PM
001mustang's Avatar
001mustang
for mild mod could use specs in tom monroe's sbf book.
otherwise you must factor in rpm, pump flow, etc.
Old Feb 11, 2011 | 10:31 AM
.boB's Avatar
.boB
I assume you're talking about Bearing Clearance
Main bearings .0015-.0020
Rod Bearings .0015-.0020
http://www.popularhotrodding.com/tec...ine_specs.html
6bangr
Feb 15, 2016 07:40 AM
KingRando
Oct 2, 2015 08:06 AM
allenmaty
Sep 24, 2015 09:17 AM
Offendant
Sep 23, 2015 07:21 PM
ccdguy
Sep 19, 2015 05:20 PM
