clutch's
Old Feb 14, 2011 | 06:18 PM
05gtgreen's Avatar
05gtgreen
Default clutch's
I was wondering if there is much difference between a 10 and a 10 1\2 inch clutch. I have more or less a stock 289 and plan on keeping it that way.
Old Feb 14, 2011 | 07:55 PM
frdnut's Avatar
frdnut
A good 10 inch like a centerforce dual friction would be more than enough for even a built 289...
Old Feb 14, 2011 | 09:18 PM
67mustang302's Avatar
67mustang302
10.5 has more area for contact, so they hold better. But, they're also heavier. And yes, a good 10" is more than enough for a built 289.
Old Feb 14, 2011 | 09:26 PM
05gtgreen's Avatar
05gtgreen
does anyone know where to get a 10" flywheel from. I have a clutch already. Thanks.
Old Feb 14, 2011 | 10:29 PM
67mustang302
10" clutch flywheel is standard stock cast iron. If you're going to be turning rpm though, it's a good idea to go with a steel flywheel though, and a scattershield....better to be safe than loose your feet.
Old Feb 16, 2011 | 07:53 PM
05gtgreen's Avatar
05gtgreen
Anyone have the 10" flywheel in there car. Also, anyone know where I can buy one. Thanks.
Old Feb 16, 2011 | 08:26 PM
tcrote5516's Avatar
tcrote5516
I have the centerforce dual f on mine and imo its a bit much for reg street driving. Starting from a dead stop its tough to blend. The harder you drive the smoother it is.
Old Feb 17, 2011 | 06:21 AM
2+2GT's Avatar
2+2GT
I have the C7ZZ style 289HP/BOSS 302 10.5" clutch, which is semi-centrifugal, which means the levers on the pressure plate actually increase gripping power when rpm increases. Works extremely well.
Thunderball
15
Nov 22, 2015 11:49 PM
junior04
Sep 28, 2015 10:53 AM
MacSerio
Sep 27, 2015 01:05 PM
ccdguy
Sep 19, 2015 05:20 PM
MasterLanMan
Sep 13, 2015 08:21 PM
