Random Silly questions
Old Feb 15, 2011 | 09:40 AM
Rols574's Avatar
Rols574
Default Random Silly questions
Ok so i have a daily driver 67 FB, just wanted the opinion of the experts
1. I like the inside of 66 doors but not necessarily the inside of 67's. Can I cut and paste? I asked a person who does restorations for a living once and he said no but i still have my doubts.
2. I don't smoke. Can i switch it to a DC outlet?
3. I have 1k to spend and I need to improve Ignition (new distributor, coil?), handling (want/need R&P, currently manual), breaking (still got drums, yuck!) or just keep saving for a TKO tranny (3 speed in there for now). which one should i address first and in what order should I address them?
There's probably more questions but these will do for now
Thanks
Old Feb 15, 2011 | 10:12 AM
Rols574's Avatar
Rols574
ok 2 more questions
4. whats the widest tire size without any modification if front and rear.
5. how do you feel about staggered wheels. Mustangs tend to be higher in the nose and I would like for mine to be higher in the back
Old Feb 15, 2011 | 11:17 AM
2+2GT's Avatar
2+2GT
Not a chance. Different shape panel, different shape door.
It already is a 12V DC outlet.
Waste of money on your budget, ignition upgrades are the least effective upgrade per $. Get your distributor professionally 'curved' and convert to Pertronix I.
R&P is another low-$-return item. Get a 4-turn stock box, make sure nothing is worn out.
If you drive it hard, get the stock-type front discs. It'll cost under $600.
Your 3.03 is as strong as a "toploader". When you upgrade, use a T5.
Brakes > Steering > Trans.
Mustang Wheel and Tyre Chart
The nose seems high because the 45 year old leaf springs are sagging. Get new ones. You can get GT rear springs, with new U bolts and and eye bolts and shackles for under $200.
Old Feb 15, 2011 | 12:15 PM
Rols574's Avatar
Rols574
Ok, convinced, wasn't that hard. anyone who had to stop on a dime with drums will tell you how scary that is.
any links? PM if you cant post them
what do you think of the wilwoods? I've always like them
http://www.totalcontrolproducts.com/...nt_street.html
also been interested on mustang Steve's Cobra mounting kit. Anyone has done these?
whats the difference between regular and drilled rotors?
Old Feb 15, 2011 | 12:56 PM
2+2GT's Avatar
2+2GT
Actually, one panic stop is no problem with well-maintained drums. Two in a row? That's another story…
The stock 11" brakes are easier to get parts for, cost less, and work just fine.
Regular brakes don't have holes drilled in them.
Old Feb 15, 2011 | 01:24 PM
Coupe's Avatar
Coupe
I have read that drilled rotors are not the best thing for the street, slotted at most. I am going the factory brake route, I have had them in the past on a 67 and they worked great, and I was just an abusive kid at the time!
Old Feb 15, 2011 | 02:13 PM
Rols574's Avatar
Rols574
can someone post a picture of the trunk lock? I swear mine just looks wrong
Old Feb 15, 2011 | 02:18 PM
Norm Peterson's Avatar
Norm Peterson
Current pad formulations do not 'outgas' as badly as pads in the past did. Translation: there is less need to give any gases given off by hot pad material an easier way out.
In street driving, you won't normally tax the brakes hard enough to generate enough gas to matter. The only exception would be driving in the hills/mountains.
If you open-track your car (road course), you can put so much heat into the rotors that they can and will crack at the holes.
There isn't too much in between.
Slotted rotors seem to resist letting material get embedded into the pad material, meaning that they tend to last longer before becoming grooved/scored.
As a third option, "dimpled" rotors are also available at least for some applications.
Norm
Old Feb 15, 2011 | 05:44 PM
Rols574's Avatar
Rols574
question:
most of the conversion kits (Baer, SSBC, etc) come with 4 or 6 piston calipers while the 95SN conversion from MustangSteve or StreetorTrack only have the 2 piston calipers.
Is there a stopping power difference?
Thanks
Old Feb 15, 2011 | 07:35 PM
Starfury's Avatar
Starfury
I considered a couple options for disc brakes on my 67fb a few years ago. I settled on the OE Kelsey-Hayes 4-piston disc brakes and I'm very happy with them. They're mostly a bolt-on (factory discs use the same spindles as drums, unlike other conversions which require a spindle change) and they perform very well. I drive my car hard on occasion and I've never been able to get them to show any signs of fade.
Other disc kits will be more flashy, and some may be slightly better for autocross/track use, but only marginally so, and you'd never notice on the street. The OE 4-piston setup is very good on its own.
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
mungodrums
Sep 28, 2015 10:54 PM
