Horn Button Diagram
Old Feb 19, 2011 | 01:27 PM
unit91's Avatar
unit91
Default Horn Button Diagram
Horns don't work. Jumped each horn from the battery and they both work so I know it's not a bad horn ground to body problem. Then I pulled the steering wheel to check the contacts in the horn ring assembly and now I'm looking at something that I am totally not familiar with. I was told that one of the contacts in the ring assembly is supposed to be hot all the time, but I have no idea which one. I don't even really understand how the horn system works so I don't know what to look for. I see two spring loaded contacts that come from the turn signal switch. I tested each one with a test light and there is no power. I jumped them both together and nothing happened there either. Can anybody help?
Old Feb 19, 2011 | 01:42 PM
2+2GT's Avatar
2+2GT
One of the contacts is supposed to be 'hot'. You need to look at the connections, fuses, etc.
Old Feb 19, 2011 | 03:54 PM
PaulS's Avatar
PaulS
Ford, in their infinite knowledge decided that the horns would work best if they ran a 15 amp power wire up the column to the switch and then from the switch back to the horns with another 15 amp wire to a grounded horn eliminating the relay completely.
Old Feb 19, 2011 | 07:02 PM
unit91's Avatar
unit91
I kept working on this all day and finally discovered that it has something to do with the headlight switch. When I jiggle the headlight switch wires around, the horns work. When I was driving yesterday the car shut off as if there was no current. Started back up though. Could all this be related to a headlight switch problem?
Old Feb 20, 2011 | 05:51 AM
mortman's Avatar
mortman
the circuits a completely different. I would look at the wiring harnes, bet something is broken and shorting out.
cr620
Oct 3, 2022 10:18 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
firehorse02
Nov 16, 2015 11:28 AM
lincolnshibuya
Oct 6, 2015 08:45 AM
Sep 30, 2015 12:39 PM
