Structural repairs start on the 67 Convertible
for the start was wondering ... where are the additional holes for the shelby drop? Found them in the later pictures though.
I had that rpm cam running for a while until i flattened a lobe or two (probably since I had it). Liked it a lot with the rest of the combo (heads/intake etc). was very 'forgiving' at bottom end compared to the the XE268H. very streetable
Have you thought about a new rear end as well? Or changing the gear ratio? Speaking of, what is the current ratio?
Why would the tranny choice have any particular rear end requirement? Drive shafts can be shortened and different U-joints installed (even so-called "conversion U-joints") that should make most any combination come together.
Norm
I'm probably missing something, but . . .
Norm
Norm
If I pop the toploader in there I most likely just keep the 3.0 in there for now.
Yep I failed to mention the Shelby drop. I bought the template and drill bit from Daze. Went without event so it was kinda like why mention it. LOL
