csrp swap
Old Feb 22, 2011 | 08:44 PM
ky_67mustang's Avatar
ky_67mustang
dennis, when I called csrp I didn't rant, rave or get smart whatsoever. I called to see if maybe I had been sent the wrong mc and pushrod. The pushrod was 1/4 inch longer than original when adjusted in all the way. I was told it would work. It might have, but I was afraid the pedal position would be off. As far as the lines go, I was under the assumption that the kit came with adapters for my stock lines, there weren't any. I was told they were in the kit, and that my car wasn't like any he had seen. I was basically told I was wrong. I just wanted suggestions.
Old Feb 22, 2011 | 11:22 PM
001mustang's Avatar
001mustang
Originally Posted by 2+2GT
Not on this planet. Long before you get adequate front brake pressure, the rear wheels will lock, the car will swap ends, and a utility pole will provide stopping power.
One example i can give you is a guy that removed proportioning valve because he was not getting enough rear wheel braking in his disc/drum street rod.
granted his rear tires are plenty wider than his front tires.
it is possible, even on this planet, to have a case for no PV.
i do agree that most (not all) disc/drum setups require a PV.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Bokeo
Oct 10, 2015 08:28 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
guitarman376
Sep 30, 2015 05:54 PM
UrS4
Sep 30, 2015 10:13 AM
