help: flywheel/clutch
Old Feb 28, 2011 | 05:41 PM
  #21
.boB's Avatar
.boB
Originally Posted by roka-88
http://www.summitracing.com/parts/CT...ter%7c10.50+in.
If I decide to purchase flywheel, will this work? What's the importance of tooth count?
No, that won't work. You need to match up two important specs:
1. Tooth count. Just like axle and trans splines, all the teeth are the same size. To get more teeth, you increase the diameter. Standard teeth count is 157. The 164 tooth wheel is to increase the diameter. That also changes block plate, bellhousing, and clutch parts (hat and disc). It will improve clutch holding power, but usually also increases pedal effort. I don't think you're making enough power to worry about it. And a bigger flywheel/clutch is heavier - not a good thing usually.
2. Balance: early engines have a 28.2oz external balance. Later engines have a 50oz external balance. Custom built racing engines have 0oz external balance. The flywheel, crank, and front balancer all have to match.
I called a shop and he said it may weaken it to the point where I start getting hot spots. Is this something I should worry about? Future problems?
See post #12
Old Feb 28, 2011 | 11:05 PM
  #22
roka-88's Avatar
roka-88
ok, so I found out I can purchase a Brake Rotor Flex-Hone local (sears). What grit would be best?
http://www.sears.com/shc/s/search_10...=1298955951646
Old Mar 1, 2011 | 06:15 AM
  #23
rmodel65's Avatar
rmodel65
Yukon Cornelius
how are you gonna keep the material you remove uniform?? you need a perfectly flat surface for the clutch to work...
Old Mar 1, 2011 | 07:45 AM
  #24
001mustang's Avatar
001mustang
discs trade off is heat/abuse resistance vs. smooth release.
i prefer oem type disc for experienced smart drivers and smooth starts.
i prefer racing type for disc for clutch riders and drag racers.
i have never ventured to clean flywheel DIY.
i've had several flywheels turned.
usually problem is heat checking that is so deep it can't all be turned out.
can still use a checked flywheel w/ decent performance for years; ask the 66 GMC truck. Used to pull stuck semi trucks up steep iced hill.
if lathe operator takes material off too fast then flywheel will be damaged; other words ...avoid monday morning turning.
flywheel and pp does not look bad in photo; i don't see deep damage.
if flywheel passes fingernail/razor blade test i wouldn't turn it. remove any burs. the best way to clean up the mild surface scratches may be to install new disc and drive it.
don't forget to verify throw our bearing geometry and proper adjustment.
Old Mar 1, 2011 | 07:09 PM
  #25
roka-88's Avatar
roka-88
I was wondering how this could even happen to the fw to begin with? How can I avoid this in the future
Old Mar 1, 2011 | 08:34 PM
  #26
001mustang's Avatar
001mustang
thought your pilot bearing failed.
how much slop in your pilot bearing/bushing?
Old Mar 1, 2011 | 09:43 PM
  #27
.boB's Avatar
.boB
I use a fine 120grit hone. It's slower, but you get a slightly better surface, and less chance of mistakes
You're cleaning and honing the surface, not milling it. Just like a brake rotor.
Old Mar 8, 2011 | 08:00 PM
  #28
roka-88's Avatar
roka-88
so my disc should be arriving tomorrow. what's the best way to clean all the dust/ grime of my flywhell its collected these weeks?
Old Mar 8, 2011 | 08:44 PM
  #29
.boB's Avatar
.boB
Brake parts cleaner works really well, and no residue.
P Zero
Jun 9, 2015 05:55 PM
uberstang1
17
Sep 8, 2013 10:27 AM
Blacksmoke
S197 Shelby Section
Aug 3, 2012 09:06 PM
foolio2k4
Mar 10, 2009 09:21 AM
j07gt/cs
Mar 29, 2008 02:27 AM
