Bell Housing, T5 swap question...
Old Feb 26, 2011 | 01:58 PM
synthartist69's Avatar
synthartist69
Default Bell Housing, T5 swap question...
Hey everyone,
I want to do a T5 swap on my 65 mustang. Right now it has a 4speed top loader with a 289. Eventually I will be putting a late model 347 stroker in the car so I am wondering if I should go ahead and change bell housings so that I don't waste money on the 289 T5 spacer etc? Will a late 302 bell housing hook to my 289 block until I get the funds to install the 347? Thanks in advance!
jim
Old Feb 26, 2011 | 03:36 PM
2+2GT's Avatar
2+2GT
You can use the fulcrum adapter to make the T5 bell work with your current clutch setup.
Old Feb 26, 2011 | 03:49 PM
scootchu's Avatar
scootchu
Depends on what you see down the road with your clutch mechanism. If you plan on keeping your mechanical Z bar you can either use the adapter and the old BH or like 2+2 said use the newer BH and a fulcrum adapter.
If your linkage works smoothly now I might try the plate adapter. If your linkage is a mess like mine was, go with a clutch cable or hydraulic clutch.
I have a T5 plate adapter. Give you a spectacular deal on it.
Old Feb 27, 2011 | 07:04 AM
synthartist69
So the old 289 BH will work with a late 302 block if I decide to build a 347?
Old Feb 27, 2011 | 07:55 AM
2+2GT's Avatar
2+2GT
Sure. The 1965-2011 Ford smallblock all use the same 6-bolt bellhousing pattern.
Old Feb 27, 2011 | 09:31 AM
synthartist69
Thanks for the info 2+2
Old Feb 27, 2011 | 09:33 AM
synthartist69
I appreciate the info Scootchu. Will keep your adapter in mind but I have been planning to buy a complete kit. Thanks again!
Jim
uberstang1
Dec 7, 2017 07:10 AM
Gary Ugarek
63
Dec 11, 2015 02:01 PM
nmra1965
Other Professional Racing
Sep 26, 2015 10:46 AM
superdavid
May 26, 2006 10:49 PM
slickman
Mar 26, 2006 07:00 PM
