flywheel bolts
Old Mar 1, 2011 | 06:43 PM
05gtgreen's Avatar
05gtgreen
Default flywheel bolts
Hi, Will my original flywheel bolts work with my new 10" flywheel that I am putting in my car? I am doing a 5spd conversion (t5 bellhousing). I currently have an 3spd auto. Also, will the bellhousing to motor bolts be the same as well? If anyone can tell me what the bolts are that are used to bolt the tranny to the bellhousing? Thanks.
Old Mar 2, 2011 | 04:01 AM
kalli's Avatar
kalli
the flywheel bolts should be the same, and the bellhousing bolts are of course the same thread, but not sure about length. I used original bellhousing.
However I would replace those bolts. especially the flywheel bolts. Use ARP.
for tranny to bellhousing. didn't you get the two pieces together?
Old Mar 2, 2011 | 05:30 AM
05gtgreen's Avatar
05gtgreen
no, i bought them seperate
Old Mar 4, 2011 | 01:29 PM
.boB's Avatar
.boB
Your car currently does not have a flywheel, it has a flex plate. It uses these bolts; they are shorter, and do not have the locating shoulders.
http://www.summitracing.com/parts/MRG-6711/?rtype=10
A flywheel is thicker, so needs longer bolts. Flywheel bolts also have a tall shoulder to keep the flywheel located, like a dowel pin.
http://www.summitracing.com/parts/ARP-100-2801/
Be sure to use a thread sealant on the new bolts. Most small block cranks are drilled right through the flange, and into the crank case. If you don't seal them, you'll get a big leak.
Old Mar 4, 2011 | 02:11 PM
FoMoJoe's Avatar
FoMoJoe
2nd the thread sealant. A must!
Old Mar 4, 2011 | 03:12 PM
05gtgreen's Avatar
05gtgreen
Ok, I will just order them all from modern driveline then. What thread sealant do you recomment? Would a blue loctite work? Thanks.
Old Mar 4, 2011 | 08:01 PM
.boB's Avatar
.boB
Blue lock-tite is not a thread sealant, it's a thread locker. I use Permatex teflon paste.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
baddog671
Jul 26, 2016 01:20 PM
junior04
Sep 28, 2015 10:53 AM
2poor4u2
Sep 26, 2015 11:08 AM
maestro1024
Sep 21, 2015 02:40 PM
