Straight 6 200, Duraspark II or Petronix?
I'm looking to upgrade the ignition on my straight 6 200. Its currently has a plain Jane single vacuum advance points-based distributor. I'm wonder which will give me a better improvement: going to a Duraspark II setup, or replacing the points with Petronix? Both will end up costing me about the same.
Thanks for the input,
Scott
Scott
I've had both and never really noticed a difference between them. Pertronix would be easier to do since its just 2 wires. The duraspark 2 system has a module you have to wire up and I believe it is 5 or 6 wires maybe more..
I fried 2 or 3 coils trying to get the duarspark 2 to work correctly.
I've been doing a lot of reading, it seems 6 this way or half a dozen that way with petronix vs DSII. I've also read that the best thing to do with either setup is add a multispark MSD box into the equation. I just so happened to run across one for $60 yesterday. Anyone have any experience in that department?
I don't know anything about Duraspark. I have a 1965 I6 200 motor and put on the Petronix I Ignitor with a Petronix coil. It was very easy to put on and the car has ran well with no problems (at least with the ignition).
the pertronix I is easier as you don't have to remove (or better bypass) the resistor wire
However the pertronix has the advantage of
- adaptive dwell (it changes dwell angle at higher rpms). Something you cannot achieve with pert I or points system
- it switches off automatically I think when ignition is on but engine not running (after a while). I believe that's what kills most pertronix I: ignition left on for testing or radio or forgetting.
nmra1965
Other Professional Racing
Sep 26, 2015 10:46 AM
