Dimmer Switch Location
Old Mar 22, 2011 | 07:22 AM
boeing747arowair's Avatar
boeing747arowair
Default Dimmer Switch Location
Can any of you please give me dimensions of where the dimmer switch goes? I Replaced full floors and need to install my switch now.
thanks,
Old Mar 22, 2011 | 09:51 AM
69mach1377's Avatar
69mach1377
Unless you are going for concours, you now have the opportunity to customize it to your preference...
Old Mar 22, 2011 | 09:58 AM
boeing747arowair
No concours here, just wondering. When i buy the carpet will it come with the hole and grommet for the switch already in it or no? If not i will place within the area.
Old Mar 22, 2011 | 02:41 PM
69mach1377's Avatar
69mach1377
Mine did not. I cut an 'x' in it for the button to fit thru.
Old Mar 22, 2011 | 02:57 PM
boeing747arowair
Excellent thank you man. Can any1 with 65-66 tell me if the carpet comes with a grommet or if it is installed by cutting the X
Old Mar 22, 2011 | 10:13 PM
Jonk67's Avatar
Jonk67
I can't say if the dimmer switch was in the exact same location on a '66 compared to '67 but here's some pics of my stock placement on my '67 if it helps
1 7/8" from wall to lower mounting hole center
Center of switch 8 1/2" up from floor seam, 7 3/4" to center of lower mounting hole
Jon
Old Mar 23, 2011 | 07:26 AM
boeing747arowair
Jon Excellent thank you so much
Old Mar 23, 2011 | 09:11 AM
Jonk67's Avatar
Jonk67
No problem, I come across that question every 3mos. and luckily took a pic when I was in there. Looking at the tape mark on my pic I think this quote
"1 7/8" from wall to lower mounting hole center" for the first pic is more like 1 3/4"
Jon
lincolnshibuya
Jul 5, 2020 03:05 AM
PaulH2
20
Jan 31, 2016 09:48 AM
guitarman376
Sep 30, 2015 05:54 PM
jc409
Convertible Tech
Sep 26, 2015 08:28 AM
Colin Ringle
Sep 15, 2015 09:27 PM
