T5 conversion help
Old Apr 16, 2011 | 08:07 PM
synthartist69's Avatar
synthartist69
Originally Posted by BA Mustang
I read up and it said to put the spacer 1" into the opening. Same one said to place it touching the oval piece that is inside there, but that was more than 1".
http://www.fordmuscle.com/archives/2...wap/index2.php
Thanks for the article! This will be very helpful as well...
Old Apr 16, 2011 | 08:09 PM
synthartist69
Originally Posted by kalli
347 and T5? that works? i always thought the T5 will shatter with that torque ?!
I went with the T5z, a little tougher than the T5. I don't plan on trying to rip the transmission and rear end out of the car taking off, just spirited hot rodding.
Old Apr 16, 2011 | 08:11 PM
synthartist69
Originally Posted by 67t5ponycoupe
BA My method will show you exactly where the block should be mounted. I would then compare that to waht the article said.
I'm running a 347 stroker and could not be happier with the whole set up.
What cam are you running in your 347? I decided to go with the F303. Just building this for a mild street racer.
Old Apr 17, 2011 | 05:06 AM
kalli's Avatar
kalli
Originally Posted by 2+2GT
Not as long as you operate the clutch as an adult. I got years of service out of a 2.77 3-speed, the so-called "paper transmission", and I even did some trailer-towing with it.
good to know. but I know what you mean with operating it like an adult. I thought going through the gears and flooring it would be too much already.
HRnB
GT350 S550 Tech
Dec 18, 2015 09:35 AM
Nov 10, 2015 11:39 AM
DCole24
Sep 11, 2015 10:50 AM
YoungStangsMan
Sep 5, 2015 07:01 PM
