Kickdown Rod Needed?
Old May 2, 2011 | 10:17 AM
MetalmanUtah's Avatar
MetalmanUtah
Default Kickdown Rod Needed?
I have a 1964 1/2 Coupe. 302 V8 auto with two-barrel carb. My mechanic recommended I have a kickdown rod installed.
Is this necessary? What's the benefits?
Thanks.
Old May 2, 2011 | 10:26 AM
TexasAxMan's Avatar
TexasAxMan
Yes, you need a kickdown with an auto.
Old May 2, 2011 | 10:36 AM
MetalmanUtah
Pardon my ignorance, but what is it for? And what problems can be caused if I don't have one.
Old May 2, 2011 | 11:09 AM
2+2GT's Avatar
2+2GT
It will accelerate like crap if you don't have it. The kickdown drops the trans into a lower gear when you stomp on the gas.
Old May 2, 2011 | 11:13 AM
MetalmanUtah
This something I can do myself?
Old May 2, 2011 | 11:16 AM
rtintwo's Avatar
rtintwo
It is a rod or cable that goes from your throttle linkage on the carb to the tranny. During high load or harder acceleration the rod will make the tranny down shift to a lower gear so the engine will make more power.
It wont cause any harm to not have one however you wont have much power for acceleration or for going up hills. Your 302 will feel like it bogs down and wont respond the way you would like it to. I would very strongly recommend that you get a rod or cable.
This is a link to a 66-68 cable. With the 302 in a 64 i dont know for sure it will work with your set up but it will be close.
http://www.cjponyparts.com/scott-dra...1968/p/HW1249/
Old May 2, 2011 | 11:30 AM
2+2GT's Avatar
2+2GT
The lower drawing shows your car:
http://www.ford6v.com/images/65-66mu...ink%5B1%5D.jpg
Old May 3, 2011 | 02:47 PM
PaulS's Avatar
PaulS
The "Kick-down" linkage does more than just kick into a lower gear.
It modifies line pressure, modulator pressure and governor pressure to keep enough pressure applying the clutches and band to prevent slippage under load.
measuring the pressure when in drive above 55 mph (there is no downshift above 50) while cruising and then at WOT at the same speed will show an increase in line pressure of up to 25%.
You can ruin the transmission operating without the "kick-down" linkage functioning.
It is not a throttle pressure linkage but it does affect throttle pressure via the modulator valve.
NorthAmericanTuning
Nov 9, 2016 11:45 AM
NorthAmericanTuning
Mar 18, 2016 11:21 AM
Cit95
Sep 22, 2015 07:08 AM
defarmer
Aug 13, 2015 06:40 AM
Darrens07GT
Aug 10, 2015 03:59 PM
