Granny Tranny
Old May 17, 2011 | 08:32 PM
olTRASH's Avatar
olTRASH
Default Granny Tranny
I have read a lot of posts regarding clutch chatter. I've also read that worn z-bar bushings can contribute to the shaking when starting from first. I checked the z-bar and WHAM!, that baby's loose! New bushings on the way. I also noticed a bit of oil between the rubber clutch boot and the bell housing.
If there is oil there, is that a clear indication of oil contamination in/on the clutch? I don't see any signs of oil coming from anywhere but inside.
How loose(tight) should the connection be between the z-bar and the ?plumb bob adjuster?
I am also noticing when at the upper end of 1st it has a loud whining, almost like a tilt-a-whirl starting up if you know what I mean. Gear going out? something more exciting?
Any input is appreciated.
1st post. I owe a case.
Old May 17, 2011 | 08:42 PM
MustangFTW
Guest
Posts: n/a
i think you need one of these:
and one of these:
i think thats all
welcome to the forum
Old May 18, 2011 | 10:21 AM
scott_m_mil's Avatar
scott_m_mil
I think the only way to find out if there is oil on the clutch is to drop the transmission and have a look. As far as whining it could be a couple of things including just normal noise. While you've got the transmission out to inspect the clutch, take the top cover off and look for any obvious damage or excessive wear. To be honest its only a few hours of work on these cars.
Scott
Old May 18, 2011 | 02:24 PM
2+2GT's Avatar
2+2GT
make sure to put a zerk fitting on the equalizer tube to keep it filled with grease. The bushings will pretty much last forever after that. Some come with them, although it's not original.
Pry the lower pushrod away from the release lever until there is no slack in the linkage or lever. The gap should be 1" at the tip of the pushrod.
Old May 18, 2011 | 02:54 PM
TexasAxMan's Avatar
TexasAxMan
Thanks for letting us know about that. I didn't know there was a zerk on it, I'll have to check when I get home. If there is not one on mine, should I drill, tap and install one, or are some of them different and don't need it? Also, is there a specific place it should be?
Old May 18, 2011 | 05:53 PM
2+2GT's Avatar
2+2GT
Just place it so it's easy to get to with the grease gun. If it's a show car, you might want to compromise and hide it. Keeping the tube filled with grease really helps the bushings hold up.
treesloth
Sep 28, 2015 07:03 AM
2poor4u2
Sep 26, 2015 11:08 AM
prophotog
Sep 15, 2015 08:38 AM
jaiidutch
Sep 14, 2015 10:29 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
