Thermostat housing
Old May 29, 2011 | 09:16 PM
mr_velocity's Avatar
mr_velocity
Default Thermostat housing
I need to replace my thermostat house with a 90 pointing up (needed for the March kit). I notice my intake has a hole for this, but what is the extra port for on the housing (looks like 5/8"), see pic below. Also, while I have your attention, should I run a 185 degree T state in my 302? This is the first motor I've built that had a water pump.
Old May 29, 2011 | 09:35 PM
Derf00's Avatar
Derf00
Gentleman's Relish
probably a heater core outlet.
Old May 29, 2011 | 09:42 PM
67t5ponycoupe's Avatar
67t5ponycoupe
It is for the bypass hose that goes down to the water pump. All small block fords run them. It requires a hose with a prebent 90 degree bend in it.
Old May 30, 2011 | 07:53 AM
kalli's Avatar
kalli
yes 185 thermostat should be good in a 302. I run that as well. i wouldn't go colder
Old May 30, 2011 | 09:58 AM
scootchu's Avatar
scootchu
Just for the record I run 195° t-stats in my 302 and 289 and have no problems. You don't want it to run cool.
Old May 30, 2011 | 12:12 PM
mr_velocity
Thanks guys. Like I said, this is the first motor that has had either a t-stat or a water pump. My big blocks have been for the boat, they are sea water cooled so we just run a cross over that will push the water into the blocks. Also don't run a t-stat, with the heavy load I've never had an issue getting them hot.
Looks like another summit order going in today
Nick Oliver
Oct 17, 2018 04:22 AM
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
nmra1965
Other Professional Racing
Sep 26, 2015 10:46 AM
MusicCity615
Sep 12, 2015 07:05 AM
Granatelli Sales
California Regional Chapter
Sep 11, 2015 01:11 PM
