toploader 4 speed linkages
Old Jun 4, 2011 | 08:28 PM
jimmy428's Avatar
jimmy428
Default toploader 4 speed linkages
does anyone know how to put these on. My first time messing with a manual and I need info on which linkage corresponds to which lever on the side of the toploader. its a 68 302 4 speed and im trying to put the trans shifter and linkages on. Thanks.
Old Jun 4, 2011 | 10:03 PM
jimmy428's Avatar
jimmy428
i've set the trans to neutral manually using one of the ears.
I know that furthest left is 3/4, middle is reverse/not, and furthest right is 1/2
i know which ones on the control box are 1/2, 3/4, and reverse
my issue is i don't know how to orient the ears or arms.
if anyone has a picture of their 4spd toploader with the shifter all attached and working, please let me see it. I would greatly appreciate it. Thanks.
Old Jun 4, 2011 | 10:26 PM
jimmy428's Avatar
jimmy428
pretty sure i got it, but post your pic just in case. i'm buying some bolts tomorrow to test it out.
Old Jun 5, 2011 | 09:19 PM
frdnut's Avatar
frdnut
I don't have any pics of mine but you can easily figure it out by turning the input shaft and watching the output shaft...4th gear is 1:1 ratio so the output shaft will turn the same as you turn the input...Once you have that you know you have the 3/4 lever so the other one is obviously 1/2...The reverse lever only moves in one direction and of course the output shaft will turn backwards...Don't forget to move the lever back into the neutral position or you won't be able to shift into any other gear...
UrS4
Oct 3, 2015 06:23 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
BeatnikFink
Oct 1, 2015 08:00 PM
mungodrums
Sep 29, 2015 09:18 PM
musnicki
Sep 23, 2015 07:11 AM
