Torque converter
Old Jun 8, 2011 | 09:28 PM
67stangr's Avatar
67stangr
Default Torque converter
Should the torque converter be instaled on the engine or trans or does it matter?
Old Jun 8, 2011 | 11:15 PM
PaulS's Avatar
PaulS
It matters very much. The converter should always be installed into the transmission before the transmission is put in place.There is almost no way that you could align the converter with the pump if you attached it to the engine first.
Make sure it is completely seated in the transmission or you will break the pump when you pull it together with the bolts - It should slip flat against the engine without tightening any bolts.
cr620
Oct 3, 2022 10:18 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
jerrytubes
Oct 23, 2015 12:11 PM
guitarman376
Sep 30, 2015 05:54 PM
wraith777
Sep 28, 2015 10:49 AM
