auto shifter removal?
Old Jun 25, 2011 | 01:14 AM
stangcoupe1970's Avatar
stangcoupe1970
Default auto shifter removal?
I'm trying to remove the shifter on my '70 to repair it but it seems to be held on by a wire going into the drivers side but I don't see a way to disconnect it.
is there an easy way I'm over looking?
Old Jun 25, 2011 | 06:45 AM
rtintwo's Avatar
rtintwo
The wires run under the car and have a plug in the engine bay on the firewall, typically a few inches away from the brake master cylinder. If you crawl under the car and look at the bottom of the shifter you will be able to see the wires and trace them back to the plug.
Old Jun 25, 2011 | 07:19 AM
2+2GT's Avatar
2+2GT
If you are trying to replace the bushings, this can be done with the shifter in the car. Remove the chrome lever, go under the car, slide the lower lever out, clean out the remains of the old bushings, insert the new ones, and put the lever back together.
Old Jun 25, 2011 | 09:39 AM
stangcoupe1970
the plate that holds the shifter to the car is cracked around the top 2 bolt holes.
Old Jun 25, 2011 | 11:53 PM
stangcoupe1970
got the shifter all put together, I know the bushings need replacing but it seems to me that the lever is bent or some thing. when the lever is in park and wont go any further up I believe its either in neutral or reverse. could the bushings throw off the position that far or is there an underlying issue?
the shifter arm is adjusted so the end of the sleeve as well...I dont think it should be out that far.
Old Jun 26, 2011 | 06:53 AM
2+2GT's Avatar
2+2GT
Originally Posted by stangcoupe1970
when the lever is in park and wont go any further up I believe its either in neutral or reverse. could the bushings throw off the position that far?
You bet they could. There is also a rubber bushing where the lower end of the shifter attaches to the shift rod, or should be.
carid
Jul 8, 2016 09:55 AM
Boostaddict
2.3L Eco-Boost Tech
Nov 24, 2015 06:11 AM
rksnow1
Sep 14, 2015 08:46 PM
fastbackford351
Sep 12, 2015 09:42 AM
vintageaion
Sep 8, 2015 10:45 AM
