Radio Problem
Old Jul 20, 2011 | 08:06 PM
200ci66's Avatar
200ci66
Originally Posted by JMD
That means the radio IS NOT grounded, it is grounding through the antenna cable.
There is no telling what happened to it when it was "hunting" for a ground....
This may seem like a very stupid question, but is the ground from the antenna sufficient enough to make the stereo run properly? If no, then I think that may be the answer to the problem.
We'll also pick up some speakers this weekend to see if the lack of speakers is the reason behind it not working.
Old Jul 20, 2011 | 09:26 PM
JMD's Avatar
JMD
Originally Posted by noroof66
Pull out the speakers and try it, I bet one connection is touching metal and grounding out.
I didn't think about that, thanks for the tip, I will check it out.
The lack of ground could be your issue, but most antennas are are grounded right to the radio case, meaning that a good ground wire MIGHT help your issue, but I don't think it will work for you at this point...
Old Jul 21, 2011 | 07:46 AM
jaw1962's Avatar
jaw1962
My radio would not work just by grounding it with the antenna. It required its own ground to the body before it would work.
Old Jul 21, 2011 | 10:22 AM
200ci66's Avatar
200ci66
Did it do what I am describing? Turning on and producing a hum? or did it just not turn on at all?
Old Jul 21, 2011 | 10:52 AM
200ci66's Avatar
200ci66
EDIT: NEVERMIND!!!! Right when we were ready to give up, it decided to work. No idea how. Clueless. But it's working. Now onto the rest of the interior
Thanks for the help guys.
Old Jul 21, 2011 | 11:46 AM
Iskwezm's Avatar
Iskwezm
using 2 or 4 speakers would have no effect on the radio working or not. If the radio NEEDS the antenna to turn on, it had a weak ground or the ground on the circuit board isnt good.
vbonina
Sep 22, 2015 08:31 AM
Gkid182
Sep 22, 2015 08:17 AM
Beerman309
Sep 19, 2015 01:16 AM
unit91
Sep 15, 2015 09:53 AM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
