Choke Tube Problem
Old Jul 7, 2011 | 10:10 PM
ChesterKaup's Avatar
ChesterKaup
Default Choke Tube Problem
The choke tube on my 1966 289 mustang fits in the exhaust manifold very loose. Is there someting I can use to seal it, glue it or make it fit snug?
Old Jul 8, 2011 | 05:46 AM
rtintwo's Avatar
rtintwo
20 bucks for a new set.
http://www.cjponyparts.com/CHOKE-TUB...66/p/MUK1001O/
Old Jul 8, 2011 | 09:34 AM
ChesterKaup
It is a new set. When I drilled out the old one in the exhaust manifold I made the hole to large.
Old Jul 8, 2011 | 09:38 AM
67t5ponycoupe's Avatar
67t5ponycoupe
Pull the manifold, weld the holes and redrill them, or replace the manifold. The hole should be 1/4 inch.
Old Jul 8, 2011 | 11:04 AM
kalli's Avatar
kalli
i wouldn't bother. it's just picking up warm air there . try a metal tube that fits in manifold and original choke goes in there. The tubing is metal under the sleeve, so even if the hole is too big you can bend it in there and it will stay
if you have headers instead of manifold people just wrap the tube around one of the header pipes.
sole purpose of this tube is to pick up hot air. nothing else
Old Jul 8, 2011 | 02:51 PM
jlg2002's Avatar
jlg2002
The fit is not that critical. Unless it's ratting or falling out, its best to leave it alone or a little high temp epoxy should do the trick.
FYI- the last time i spoke with a machine shop, cast iron manifolds won't take a weld.
Jb145700
Aug 21, 2022 06:37 AM
SSG Steggy
3.7L V6 Technical Discussions
Nov 5, 2015 03:09 PM
Luke9222
Oct 22, 2015 11:55 PM
BrantleyS550
Sep 14, 2015 04:18 PM
MasterLanMan
Sep 13, 2015 08:21 PM
