Engine tuning Carb issues .
Old Jul 24, 2011 | 01:01 PM
67Eleanor's Avatar
67Eleanor
Post Engine tuning Carb issues .
Hello i have a 289 engine i have installed an edelbrock performer manifoldhttp://www.mustangsunlimited.com/itemdy00.asp?T1=EDL21211+01 and a edelbrock 500cmf 4 barrel carbhttp://www.mustangsunlimited.com/itemdy00.asp?T1=EDL1404+01
and an edelbrock racing fuel pump http://www.mustangsunlimited.com/ite...?T1=EDL1725+01
The problems i have is that i have very hard time to get the car to start , when it starts i have black smoke and it stinks of gas , when the i rev the car on neutral its ok although before i had spot on response now it little slower in response , when i have it in gear and i hit the petal the engine stalls and it stops .
Please advise me
thank you
Old Jul 24, 2011 | 04:15 PM
67mustang302's Avatar
67mustang302
Carb too rich in the idle circuit maybe, prolly the accelerator pump and jetting.
Old Jul 25, 2011 | 08:27 AM
rtintwo's Avatar
rtintwo
Put your old pump back on. 500cfm doesnt need a high volume pump. After the old pump is on look inside the carb, when running, for gas pouring down the venturi. The eddy carbs are very fuel pressure sensitive and prefer lower pressure.
Old Jul 25, 2011 | 11:28 PM
67mustang302
A high volume pump won't matter as long as the fuel pressure is right. If the fuel pressure is correct the needle will close on the seat and regulate fuel flow. The Edelbrock pumps have built in pressure regulators that are pretty accurate.
Old Jul 26, 2011 | 12:29 AM
67Eleanor's Avatar
67Eleanor
Hello i have tried a few of the tips your suggesting and they worked i have noticed that my ignition timing needs adjustment too but i dont know the correct positions to start with on this 289 does anyone have any experience on how to set everything in order so i can start timing ?
djbigskrilla
Sep 20, 2022 01:04 AM
mtxplod
Aug 29, 2015 01:43 AM
5.0pntydrpr
Aug 27, 2015 10:26 PM
mweiland
Aug 13, 2015 05:11 PM
Jacob4589
Aug 8, 2015 11:00 AM
