Quad headlights
Old 07-30-2011, 07:03 PM
Stangman70
Stangman70's Avatar
Default Quad headlights
So this may be blasphemous to some of the original guys out there, but I was thinking of going to a quad headlight set up on my 70 coupe. Could I just just swap the headlight buckets and fenders from a 69? Where would that put my turn signals? Were there any special marking light differences from 69 to 70? Has anyone else done this swap?
Stangman70 is offline
Old 07-31-2011, 01:46 AM
andrewmp6
andrewmp6's Avatar
I think it would be fenders front valance grill head light buckets and the marker lights are probably different.
andrewmp6 is offline
Old 07-31-2011, 01:10 PM
69mach1377
69mach1377's Avatar
Quads Rule!
69mach1377 is offline
Old 08-01-2011, 07:33 AM
Stangman70
Stangman70's Avatar
@andrew, do you think that the added headlights will play with my existing harness? Should I pull one off the donor car?
Old 08-01-2011, 03:21 PM
Flash70
Flash70's Avatar
There is a different harness for quads because I had to adapt mine to add more lights. While I did the mustang headlight relay upgrade I was able to add extra lights with no additional effort. Cost me probably $30 for all the stuff I used.
Flash70 is offline
Old 08-01-2011, 04:08 PM
1971mach1
1971mach1's Avatar
Instead of changing the fenders (and whatever else needed), why not just add 2 lights to the center of the grill,,,, like a 1967 Shelby?
1971mach1 is offline
Old 08-01-2011, 04:24 PM
Excessv
Excessv's Avatar
I might would consider adding the lights as well.
Excessv is offline
Old 08-02-2011, 01:20 AM
andrewmp6
andrewmp6's Avatar
It could be wired in to the headlight wiring harness now but i would do all 4 a h4 swap.
FivePointToTheOh
03-09-2020 10:26 PM
StalkerGT
11-28-2015 03:09 PM
Seanam
10-04-2015 10:15 AM
Drastang
09-29-2015 03:31 PM
Mobiusone stang
09-07-2015 08:46 PM
Quick Reply: Quad headlights
