Pulsating Lights??????
Old Aug 19, 2011 | 05:38 PM
wonso79's Avatar
wonso79
Question Pulsating Lights??????
Hi everyone, turn the mustang on this morning and the lights were pulsating. Recent changes, new headlight wiring harness, voltage regulator, headlight bulbs, parking lights.
When crusing with accelator down the lights puslate even in the dash, once I let off the gas the pulse stops and lights remain on constant.
Any thoughts as to what could be causing this?
Old Aug 19, 2011 | 07:14 PM
TexasAxMan's Avatar
TexasAxMan
my guess would be to start with the regulator. Sometimes new ones are bad.
Old Aug 19, 2011 | 09:45 PM
Oxnard Montalvo's Avatar
Oxnard Montalvo
I agree, there's a good chance it's the voltage regulator. It's a common problem. The contact points inside the regulator vibrate electrically. Buy an electronic voltage regulator. $30-$35 bucks at Napa.
Old Aug 20, 2011 | 07:53 AM
wonso79's Avatar
wonso79
I'll have to pick one up and see if that fixes the problem, pisses me off that I just spent 30 bucks on a new one, I should have left the old one in there! Thanks guys
Old Aug 20, 2011 | 12:37 PM
Jonk67's Avatar
Jonk67
Check all your grounds again also, loose/bad ground may have enough contact at idle but not enough when amps increased by alt. spinning faster. All your grounds should be to bare metal, no paint, rust, etc. between wire and metal.
Jon
Old Aug 20, 2011 | 12:49 PM
FoMoJoe's Avatar
FoMoJoe
Time for a new alternator. It's going out on you...
Old Aug 21, 2011 | 07:01 AM
wonso79's Avatar
wonso79
Smile
I'll check all the grounds again, it can't be a the alternator it's new as well.
Old Aug 22, 2011 | 05:40 AM
kalli's Avatar
kalli
check the voltage over battery on idle and start revving slowly (more and more) and see what it does.... if it creeps past 14V the voltage regulator needs looking at. I wouldn't be surprised to hear it goes all the way up to 16V....
Old Sep 5, 2011 | 03:31 PM
wonso79's Avatar
wonso79
Yep, it was the voltage regulator!! I had just put a new one in from CJ Pony Parts a few months back and had to replace it with a new one from Napa Auto Parts.
jwog666
Dec 27, 2021 08:09 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Explosive
Oct 2, 2015 07:45 AM
ChampInSD
Oct 2, 2015 04:55 AM
