Tire pressure
Old Sep 6, 2005 | 02:03 AM
earlymustang's Avatar
earlymustang
Default Tire pressure
Confused about what tire pressure to use. Recommendation for High Performance is 28psi, non 24psi. There is also a decal for redline tires that I can't make out the psi in the NPD catalog. Also, the glove box decal recommends adding 4psi if driving over an hour over 60 mph. Any help on proper inflation would be greatly appreciated.
195/70/14 Firestone radials
Old Sep 6, 2005 | 04:49 AM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Tire pressure
I drive mine with between 28-30 psi, and have been for years. If it is too low, you will notice the sidewalls starting to wear, and if it is too high you will notice the center of the tire to wear more than the rest.
Old Sep 6, 2005 | 10:30 AM
69mach1377's Avatar
69mach1377
Yeah, both of those sound a little low for modern radials...
Old Sep 6, 2005 | 10:48 AM
earlymustang
I just checked mine. They are about 23-24psi.
This may be why it has felt a little sluggish at the line and around corners?
Max psi on side of tire is 44
Old Sep 6, 2005 | 01:53 PM
Soaring's Avatar
Soaring
I ♥ Acer
Read: Max is 44. That certainly does not mean you put 44 in them. You might try 32 for a few miles to see how it drives, then if it is a little bouncy, cut her back to 30 and see how that feels.
jwog666
Dec 27, 2021 08:09 PM
CS2007
Jun 25, 2019 09:45 PM
svfetter
Oct 5, 2015 11:39 AM
88 orangepeel notch
Oct 5, 2015 09:03 AM
marc954
Sep 29, 2015 11:18 AM
