fuel priming
Old Sep 27, 2011 | 08:45 PM
stangcoupe1970's Avatar
stangcoupe1970
Default fuel priming
I'm trying to get the 70 to run on its own and I put about 2.5 gallons in the tank and poured some into the carb to get it to start and spin the eccentric for the pump. I have a see through fuel filter and its dry inside.
do I need more fuel or am I doing something wrong?
Old Sep 27, 2011 | 09:59 PM
PaulS's Avatar
PaulS
use a small bottle to pour some gas into the vent tube of the carb - that will fill the bowl and feed the carb long enough to get the fuel from the tank
Old Sep 27, 2011 | 11:33 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
got an air compressor?? take a rag and wrap it around the air hose and stick it in the filler neck apply air while youre turning the engine over it will push the full up...
Old Sep 28, 2011 | 09:58 AM
kalli's Avatar
kalli
aye. that's the easiest way to do it. don't overfill. agitate throttle once to close choke if you have one, and spray a little into the intake
don't pour it straight down the carb, that will probably just soak the sparkers
Old Sep 28, 2011 | 03:49 PM
crunchyskippy's Avatar
crunchyskippy
In my experience, it takes about 10 seconds of cranking the engine to get fuel from the tank, fill the bowl, and into the venturi. That is 10 full seconds and it will seem like a long time of cranking. That can be hard on a battery if not recently charged.
Good luck.
Old Sep 28, 2011 | 05:02 PM
stangcoupe1970
the filter is before the pump...is that correct? my girlfriends dad told me to put it there but someone at work told me to put it after the pump.
Old Sep 28, 2011 | 10:16 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
filter goes after the pump to keep junk out of the carb...ive seen them before and after the fuel pump but that isnt stock
Old Sep 29, 2011 | 08:41 PM
stangcoupe1970
it was a fuel pump thanks for the help...heres 2 videos of it running without me pouring gas down the carb:
http://youtu.be/J84Jf9Jcpo8
http://youtu.be/3SmYsMOh6TA
does anything sound odd in the second video? kinda like someone tapping on the oil breather? or am I hearing loose things?
Old Oct 1, 2011 | 08:01 PM
hotrod351's Avatar
hotrod351
does sound like a clicking sound, my hearing isnt the best. exhaust is pretty loud though so it make it hard to hear. looks good. seems like you figured out your fuel problem by the length of time its running in the videos. my wifes been driving a 70 for years now, 302 engine, great car so far.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
jwog666
Dec 27, 2021 08:09 PM
Sixx
Oct 5, 2015 07:36 PM
svfetter
Oct 5, 2015 11:39 AM
mrappe
Sep 26, 2015 10:16 AM
