67 proportioning valve - brakes
Old Sep 28, 2011 | 07:04 PM
ranchero's Avatar
ranchero
Default 67 proportioning valve - brakes
my brake warning light has come on. shop manual says the system balance is off.
how do i recenter the valve after i fix the rear leak?
open front wheel cylinder bleed screw and bleed front system?
thanks
Old Sep 29, 2011 | 07:44 AM
dmaclaren's Avatar
dmaclaren
If the rear was leaking, the pin is now on that side. After you bleed the rear, if the pin is not frozen or stuck, it should return back to center.
If not, you have two choices.
1. take it apart and if you are there, buy a rebuild kit to save you from doing it again in the future. IT's like $50 on cugarparts.com or something like that.
2. Soften the front enough to force the pin back.
#1 is the only option if you know the unit is bad unless it's going to be a winter project.
There is always a #3 until your winter work which is to leave it, if it doesn't correct it's self, and unplug the switch.
Rebuild kit
Additional Prop valve info
I did mine and I am happy. I had a leak in the residual valve. I also have the two brake lines on the dist. block. I never used them. I can send them to you if you need some. I bought them in case I broke them while fixing it.
Old Sep 29, 2011 | 08:07 AM
2+2GT's Avatar
2+2GT
The brass thingy containing the switch in a 67 is not a proportioning valve. It's a differential valve. Unless you have disc brakes, you don't even have a proportioning valve.
Your first order of business is to find out why the warning light came on. Leak, excessive wear, badly adjusted drum brake, etc. Once that's taken care of, selective brake bleeding will extinguish the light.
Old Sep 29, 2011 | 11:48 AM
ranchero's Avatar
ranchero
thanks guys!
i keep getting name wrong, "differential" !
drum/drum setup on my 6 cyl.
Old Sep 29, 2011 | 03:54 PM
chockostang's Avatar
chockostang
Originally Posted by ranchero
thanks guys!
Yes, think of this thing as Glorified T's. Kinda, One for rear, one for front.
Same thing can be done with one T to split the Front brake circuit to left and right from dual bowl master. The rear circuit STRAIGHT trough to rear brakes.
The shuttle switch, warning light in the middle of the Differential Block does nothing but tell you ---AHH, you have no brakes on half the car.
No Magical fluid runs out of these.
Dan @ Chockostang
Old Sep 29, 2011 | 08:19 PM
2+2GT's Avatar
2+2GT
thanks guys!
No big deal, but if you order a rebuild kit for a proportioning valve, you'll be sent the wrong parts.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
mrtrodonet
Sep 19, 2020 03:12 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
Sep 25, 2015 06:42 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
