Rocker panel replacement
Old Sep 8, 2005 | 04:24 PM
pak133's Avatar
pak133
Default Rocker panel replacement
Has anyone replaces a complete rocker panel? Or does anyone know of a good link to find info for a replacement? Thanks.
Phil
Old Sep 8, 2005 | 06:12 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Rocker panel replacement
Phil, I have never done it, but my understanding is that there is an inner and an outer rocker panel for a convertible. Not sure what car you have. Anyway, I found a junk yard place on the net that may be where you can get the panel. I would think if you have welding skills, then you just cut out the old and add the new. But, like I said....I have never done it. http://www.actionsalvage.com/am/66Mustangbody.asp
Old Sep 8, 2005 | 06:36 PM
pak133's Avatar
pak133
I did a little research and here's what I found out. The full or complete rocker panel is a welded 'tube' if you will and it is 75" running from the front fender to the rear wheel house. The outer rocker is the part from the 'A' post ot just in front of the door to the wheel house and it is the outer shell. It basically means you can pull the rocker panel off, and weld on the new shell without having to pull the inner sheet metal that would attach the floor pans. If I can finsih getting the old rocker off this weekend I'm going to try to get the new one on and I'll have some pictures and more information for anyone who needs them.
These are the parts:
http://mustangsunlimited.com/itemdy00.asp?T1=50128+01
and
http://mustangsunlimited.com/itemdy00.asp?T1=D3647L+01
The guys at mustangs unlimited were pretty helpful
Phil
Old Sep 8, 2005 | 06:40 PM
Soaring's Avatar
Soaring
I ♥ Acer
Sounds like you have your stuff together. Good luck with it.
Old Sep 8, 2005 | 11:09 PM
pak133's Avatar
pak133
Got the part tonight...looks like just what I need. I'll send some more info monday if I get that far.
Old Sep 21, 2007 | 01:23 PM
smitty2kids's Avatar
smitty2kids
did you have to weld in braces and do you have pics of that? I have a 69 convertible I am just beginning to replace floor pans and inner rocker panels. any help is appreciated.
GPR
Dec 16, 2015 12:21 PM
copestang
Oct 11, 2015 07:17 AM
uedlose
Sep 30, 2015 08:01 AM
Gkid182
Sep 22, 2015 08:17 AM
wilsonro
4 Cylinder NA and Turbo
Sep 11, 2015 07:13 AM
