Degreaser help...
Old Sep 21, 2007 | 09:36 AM
droptop66's Avatar
droptop66
Default Degreaser help...
I am trying to completely degrease the under side of my 66. I have used enging degreaser, power washer, simple green, and the grease is still hanging on. Is there something out there that really works good?????
Old Sep 21, 2007 | 09:44 AM
john721's Avatar
john721
Default RE: Degreaser help...
Are you certain that your car has not been undercoated? All of the products you have listed should work. Remember that undercoating company, Ziebart? Man...that stuff was knarley...Trya small wire brush in one spot to see if it breaks it down...if not, you probably are dealing with aftermarket undercoating...
Old Sep 21, 2007 | 09:48 AM
pctjk's Avatar
pctjk
You may want to tow your vehicle to a media blasting company (Soda Blast). I've been quoted $1800 to blast my 65 coupe. Soda blasting removes everthing from the panels and frame. Lets you see the condition of the metal. I have not had anything done with soda blasting yet so I can't attest to its results. Check the phone book and local restoration shops.
Jeff
ASE-Engines
Old Sep 21, 2007 | 09:51 AM
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
try Hops bore cleaner #9 its a gun degreaser/ carbon remover if that doesnt work .......see above posts.
Old Sep 21, 2007 | 10:05 AM
Starfury's Avatar
Starfury
I wouldn't media blast it; that's just going to expose the bare metal and promote rust.
Try some undiluted Castrol SuperClean and let it soak. It'll curl your nose hairs (so try not to breathe it), but it should loosen things up. If not, it's wire wheel time.
Old Sep 21, 2007 | 10:25 AM
droptop66's Avatar
droptop66
I should have been more specific, its the drive shaft grease, and brake grease. Thanks for the info, i'll try the bore cleaner.
Old Sep 21, 2007 | 10:30 AM
TexasAxMan's Avatar
TexasAxMan
Scrape first, then use the degreaser. A big blob of grease (that is old and hardened) will take forever with just degreaser. Either wire bursh or putty knife.
Old Sep 21, 2007 | 10:37 AM
USMCrebel's Avatar
USMCrebel
i stang by my bore cleaner, if it can clean out a carbon build up in my m16 it will degrease anything, but like everyone else is saying WIRE BRUSH. it is going to a bitch getting it off, but someone has to do it.
Old Sep 21, 2007 | 11:50 AM
rlbjrcpa's Avatar
rlbjrcpa
Sounds like it might be undercoating. But if not, I had some luck with something called Greased Lightning. Sprayed it on and let it soak and then pressure washed it off - it cleaned up a lot of the grease.
Old Sep 21, 2007 | 03:15 PM
groho's Avatar
groho
go to homedepot, try chemdry stain extinguisher, oil and grease remover. Removes oil, grease, lipstick, ya, admit it, some of yuz fanatics out there havekissed the bottoms of your cars Its a non arisol concentrate, you spray on and let sit. Take it off withrags and a wire brush or plastic scraper, you should easily be able to do the bottom of your car. Did my 66 with 3 cans, and it looked great. Took it down to the oxy primer and didn't damage the paint or metal. A good wipe down the paint prep should permit you to throw on some primer or sealer. Good luck. If this doesn't clean it, then youre dealing with undercoating, yuk!
Gregz
Oct 18, 2022 03:52 PM
Sickspackstang
Apr 19, 2010 07:08 AM
smoyers
Mar 14, 2006 09:29 AM
WhItEvEnOm
Feb 24, 2006 07:29 PM
kingstrunner
Aug 19, 2005 08:39 PM
