Stroker kits
Old Nov 10, 2011 | 05:36 PM
JMD's Avatar
JMD
You can sleeve one cylinder no problem, but if you get a balanced assembly, you will need new pistons anyway....
And if I was worried about the ring thing, I would just sacrifice a few cubes and go with a 331, a 331 is about 13% smaller than a 347, but I imagine with the right build, considering some of the 331s advantages, you won't be giving up near that same 13% in hp/tq....
Remember also, if your shortblock had loose bearing clearances, the result of too much oil on the cylinders (slung on by the rotating crank) will cause (or at least make much worse) oil control issues.
Old Nov 10, 2011 | 09:16 PM
frdnut's Avatar
frdnut
EZ what is the deal with your crank?..Is it torn up too bad to be turned?..Unless you have an aftermarket block I just don't see the point in the extra coin for a forged steel crank..
Old Nov 10, 2011 | 10:08 PM
eZ's Avatar
eZ
Yea the crank was chewed up too much to be redone where the bearing had spun. As far as it being balanced why cant it be balanced with my old pistons. Reason being is the pistons are keith blacks that retail for 599. I have found some crank and rods that I can buy for about $800 all forged 4340.
Old Nov 10, 2011 | 10:12 PM
JMD's Avatar
JMD
Yea, the old pistons CAN be balanced with your new stuff, I was in "tunel vision mode" thinking about a stroker "kit"....
Sorry....
Old Nov 10, 2011 | 11:58 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
a sleeved cylinder is stronger than stock
Old Nov 11, 2011 | 12:06 AM
eZ's Avatar
eZ
yea top fuel has no problems using them lol
jwog666
Dec 27, 2021 08:09 PM
baddog671
Jul 26, 2016 01:20 PM
flash_xx
Oct 16, 2015 07:23 AM
Drastang
Sep 30, 2015 03:48 AM
